obd code reader
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prberg, Aug 17, 2008.
  1. prberg
    prberg Member
    155
    Burbank, California
  2. Patrick Wong
    18,210
    6,517
    Hi Peter,
    I personally would be hesitant to place an eBay order to a vendor outside the US. I don't think you'll have much recourse if the product does not meet expectations.
    Why not buy an OBD-II code reader from your local auto parts store (one which is speced to be compliant with Toyota CAN)? Then you will have some recourse if the code reader is not compatible with your vehicle.
    Once you have the code reader in hand, you can force a few fault codes (for example, removing the traction battery interlock switch, disconnecting a fuel injector wiring harness connector, etc.) and see what happens.
  3. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Yeah, that looks pretty interesting. Obviously ScanGuage can read and clear trouble codes and display gauges, much like this one can. But it has its own screen, and doesn't connect to a laptop, AFAIK. And on your pre-2006 Prius you can use CAN-view, which connects to your MFD. Both of those are over your price limit however. This should do what you want it to do, hopefully for a good price when the auction is over.
    Spec sheet on hardware: http://www.elmelectronics.com/DSheets/ELM327DS.pdf
