OBD II Monitor Readiness
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Sep 2, 2019.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,015
    764
    Virginia, USA
    This article Check OBD II Monitor Readiness Without A Scan Tool | JUST SMOGS® + REPAIR describes how the driver can determine whether the vehicle's computer has completed the required emission "tests" and is reporting READY for emissions testing for various manufacturers, but not Toyota.
    Is there something similar for the Prius?
    I have an OBD-II scanner which reads fault codes, but I don't think it reads readiness. I understand that usually driving 50 to 100 miles will mark all tests as completed, but don't want to risk being rejected from testing after clearing a code and then having to go back.
  2. ChapmanF
    15,560
    I don't know of such a shortcut. Techstream will show you the monitor readiness, of course.
    Just driving normally for a good lazy while ought to do the trick, unless, say, you have recently cleared a code as an alternative to finding and fixing the problem reported by the code, and you're trying to squeak in an inspection between monitor readiness and the code coming back, which I won't assume. :)
  3. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    ScanGuageII will tell you if the car is good to go for inspection. Instructions on p 35 of User Manual v. 6.2: You go to the home screen and press 'Scan' (upper left button), and you'll get 'No Codes Found', and 'Ready' or x Stored Codes and a button to view those codes.
  4. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    Torque app will do it, too. It checks for readiness.
  5. Johnny Cakes
    1,015
    764
    Virginia, USA
    Guilty! Apparently every few months I apparently purge some gas tank fumes to the ether. Luckily, our president says there's no global warming or I might be concerned. I have codes P0441 and P0455. Got a new OEM gas cap, but no love there. Very random and sometimes months in between codes.
    Thanks to all who replied. Apparently, I'd have to drop some not insignificant bucks to get a better OBD II scanner or app that would also read readiness. Kinda trying to save those bucks for the eventual repair.
