OBD II- Scanner
Discussion in 'Gen 2 Prius Accessories & Modifications' started by capcadet05, Jan 17, 2015.
  1. capcadet05
    capcadet05 New Member
    Hi I have read several posts about which scanners to purchase but am still puzzled. I don't want to pay the $125 diagnostic fee at the dealer but I am worried if I can see all the codes the car has. The red triangle with exclamation light flashed at me last week and then flashed at me a few days later during normal car operation at 15 mph. This is concerning and I would like to see what DTC is associated with this. Will a normal obdii CAN scanner find that code or do I need the proprietary tech to read that sort of incident? Any recommendations?
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Any scanner should do the trick.
    I've used my ScanGauge to read Prius codes. It worked fine. I could clear them too.
  3. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Check your oil level right now. A low oil level will make the red triangle flash.
  4. capcadet05
    Thanks, I checked the oil level and it was ok. I also had the oil level replaced so I will see if it appears again. It was odd because it only flashed momentarily and then disappeared. I assume that a scan gauge would tell me what sensor triggered this. Is that correct? The dealer said it might not unless it happened several times to record in the OBD. Also, is it just buying a standard obd scanner to get these codes or is there a specialized one for seeing what code triggered the light?
  5. Patrick Wong
    18,210
    6,514
    Mini VCI is the best available tool as this will give you essentially the same diagnostic power as the Toyota dealer tech enjoys, for a low two-digit price.
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    This has not been the tale told by many posters, using brandX scanners. Generic units are not to be trusted.
  7. john1701a
    12,833
    5,310
    58
    Just code reading doesn't work?
    It makes sense that some can't do anything else helpful.
  8. Patrick Wong
    18,210
    6,514
    Since the Prius contains multiple ECUs including many which a regular car does not have, a generic OBD-II code reader will generally fail when the time comes to read codes produced by such ECUs. For example, skid control ECU, traction battery ECU, body ECU, immobilizer ECU.
    A generic reader will usually read engine ECU DTC and sometimes hybrid vehicle ECU DTC. Don't expect much more than that.
    dslomer64 likes this.
  9. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I fully concur with Patrick on this one. The best and cheapest option is the Mini VCI.
    John (Britprius)
    dbcassidy likes this.
  10. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    Updated my AutoEnginuity reader to the latest version. DO NOT USE this program on your GENII! It caused all kinds of havoc and left me dealing with ABS and brake system problems. As I had installed this update on a different computer, I was able to go back to the previous version of the program on another computer and with it was able to clear all the specious codes that the update generated. I'm still working on dealing with the ABS problem that didn't clear.
  11. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    January 31, 2015 --- what is the latest version of the Mini VIc that folks are using with techstream? What suppliers have you had success dealing with? What is the latest update version for the Chinese pirated Techstream ? Best place to get it?
    Thanks,
    Ed
  12. Britprius
    5,194
    1,922
    Do not worry about the latest updates they are available on line. The updates mostly add new vehicles as the VCI works on all Toyota, Lexus, and Scion cars with obd2 from about 1994 on.
    John (Britprius)
    #12 Britprius, Jan 30, 2015
  13. grhybrid
    grhybrid Junior Member
    Unfortunately anything other than a Techstream is a crapshoot at best. Generic tinkertoy 'scanners/ code readers' don't access most of the modules, usually just the powertrain module and then limited data. The only reliable way to look into your Prius's electronics are with a factory Techstream. Of course all the modules are available, as well as many bidirectional functions, personal preference settings, etc. More and more independents garages are becoming equipped with factory level scanners. A few phone calls and you should be able to find one. I certainly hope any service facility you are frequenting would be properly tooled up to correctly service your Prius.
  14. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Not sure if the above poster has ever tried a mini VCI setup but basically all you need is the cable and the latest software can be downloaded online.
    Cable:
    Software: Dropbox - Techstream
    First install the cable driver, then the techstream software, then connect to the vehicle.
  15. Cadenza
    Cadenza Member
    125
    43
    LALA Land
    What's a better OS for Mini VCI Techstream - Windows XP (32 bit) or Windows 7 (64 bit)?
  16. Britprius
    5,194
    1,922
    Windows XP 32 bit is easier to set up, but once running both systems work the same.
    John (Britprius)
  17. Cadenza
    Cadenza Member
    125
    43
    LALA Land
    Would you happen to have the set-up instructions for Windows 7 ? My XP laptop is almost a decade old and I suspect it would crap out anytime now.
    Thanks...
  18. Britprius
    5,194
    1,922
    Leave it with me for a few minutes, and I'll get back with the details. Unless someone beats me to it.
    John (Britprius)
  19. Patrick Wong
    18,210
    6,514
    Windows 7, 32 bit OS would be the best choice.
  20. Britprius
    5,194
    1,922
    Ok hear goes. Load the drivers, then load Techstream, but do not open it. Go to my computer and double click on the hard drive. Scroll down to "program files (x86)" double click (from now I will call DC).
    Scroll down to Toyota diagnostics (DC)
    Scroll down to Techstream (DC)
    Scroll down to ENV (DC)
    Scroll down to IT3system (DC)
    Scroll down to Avialable function setting and change TISFunction=1 to =0 then go to file at the top of that box and choose "save".
    Job done.
    John (Britprius)
    Cd=.25, m.wynn and ftl like this.
