OBD2 Dongle Reviews
Discussion in 'Gen 2 Prius Technical Discussion' started by ydpplqbd, Dec 17, 2019.
  1. ydpplqbd
    ydpplqbd Active Member
    542
    250
    I have purchased four ("4") different dongles in order to try and find the "best" dongle for my 2006 Prius (in combination with Torque Pro). I have purchased the following dongles so far (first dongle was actually purchased by my wife for me as a gift):
    1. Golvery Car Bluetooth OBD OBD2 OBDII Diagnostic Scan Tool purchased by wife for $7.69 from Amazon;
    2. vgate iCar Pro Bluetooth 4.0 (BLE) OBD2 Fault Code Reader OBDII Code Scanner purchased for $29.20 from Amazon;
    3. ScanTool OBDLink LX Bluetooth: Professional Grade OBD-II Automotive Scan Tool for Windows and Android purchased for $49.95 from Amazon; and
    4. PLX DEVICES Kiwi 3 Bluetooth OBD2 OBDII Diagnostic Scan Tool for Android, Apple, Windows Mobile purchased for $99.95 from Amazon.
    Review of above devices:
    1. I was unable to pick up the bluetooth signal thus it did not work;
    2. Works nicely.
    3. Bought this one because I wanted to see what advantages are more expensive dongle provides. However, my phone was unable to pick up a bluetooth signal from this dongle.
    4. Works nicely but not really any better than "2".
    I will likely return items "3" and "4". And keep dongle "2".
    donbright likes this.
  2. ChapmanF
    15,486
    If your dongle comes with a J2534 DLL file, you may be able to use it with Techstream, which is a win.
    ydpplqbd likes this.
  3. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    I don’t think it’s just the file only. It has to be actually capable of J2534 pass thru. Considering theres so much Chinese knock off crap these days it’s make it a little difficult unless reputable. For example the cheap knock off vci cable or whatver. There’s several that don’t work for all functions of techstream unless it’s a good cable.
  4. ChapmanF
    15,486
    Right ... implicit in my "comes with a J2534 DLL" was "that is actually the correct driver for the dongle." :)
  5. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    I've bought two of the same over my years. I just look up "OBD2 ELM327" and they'll show up. I got my second one on amazon recently for $3. Connects to my android phone so I can use the TORQUE II app. No need to buy some pricey version, this just facilitates bluetooth communication to your car via OBD2.
  6. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    The elm version is only for like the simple software. Not really diagnostic which you need a compatible J2534 dongle.
  7. ydpplqbd
    542
    250
    I am now having trouble with the #2dongle and #4dongle (AKA PLX DEVICES Kiwi 3 Bluetooth OBD2) regarding information/data being received and processed by the Torque Pro app. IOW, the Torque Pro app is not receiving the data from the either of the two working dongles (AKA #2 and #4). Embarassingly, I have two blue icons flashing on the Torque Pro app. However, I am unable to find even a basic manual for Torque Pro so that I can decode these blue icons. When I tap on the icons flashing no further info is displayed.
    Any suggestions would be appreciated.
    PS The dongle#4 support staff suggested that I try the following:
    a. ) try communicating with Torque Pro still using dongle#4 with a different cell phone (obviously installed with Torque Pro); and
    b.) try downloading the Kiwi app (which provides information similar to Toruqe Pro). The URL for Kiwi app is as follows: Kiwi OBD - Apps on Google Play Apparently, the Kiwi app also has a version that works on iphone.
    I shall report back whether suggestions "a" or "b" have helped to resolve the problem.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    I have had good luck with VXDIAG on amazon. Works every time for me.
  9. ydpplqbd
    542
    250
    Finally found the blue icon information for Torque Pro (from another blog). I have also marked up a screenshot of icons and uploaded the file here. 12202019_Torque_Pro_screen.JPG
    The top left hand corner of the Torque Pro screen contains four ("4") blue icons as follows:
    1. The left one is GPS it will flash until you get GPS lock on.
    2. 2nd icon from left shows that the app is running.
    3. 3rd icon from left shows status of connection to the ELM327 OBD device. Flashing = Not connected. Solid Blue = Connected.
    4. 4th icon from left is connection to the car’s ECU, for this
    the ignition needs to be on.
  10. ydpplqbd
    542
    250
    #4 dongle (AKA PLX DEVICES Kiwi 3 Bluetooth OBD2) worked for the first 15 minutes of use and then quit. I did a number of things suggested by the customer service representative but ultimately the #4 dongle did not revive. And, for these reasons it has been sent back to Amazon as defective. I am now using the #2 dongle* (AKA vgate iCar Pro Bluetooth 4.0 (BLE) OBD2 Fault Code Reader) successfully.
    *- purchased dongle#2 for a little less than $30 from Amazon. While dongle#4 was a little more $100 with sales tax.
