Observation about oil dipstick insertion 'smoothness'
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by UltraJetRefill, Feb 6, 2019.
  1. UltraJetRefill
    156
    93
    Tucson, AZ
    I noticed after a few oil changes that inserting the oil dipstick in my Prius is smooth, but the one in my wife's (same year, 2017) seems to bind (grabs, maybe?) a bit. I always insert them so the flat side of the dipstick bends with the dipstick tube (if that makes sense).
    Just wondering if anyone else has noticed this?
  2. padroo
    padroo Senior Member
    2,763
    2,252
    That's the way I do it.
    Maybe the tube is damaged?
  3. UltraJetRefill
    156
    93
    Tucson, AZ
    I'll take a better look at it after work.
  4. UltraJetRefill
    156
    93
    Tucson, AZ
    Tube looks ok from what I can see. I'll have a better look tomorrow. I'll have a better look at the dipstick too. I wonder if it's just a little rough at the end, who knows.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Try your dipstick in the wife's car and vice versa, that should tell you if it's the stick or the tube.
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    You might have to twist it as it begins to bind and this should free it up. That's what I do.
    padroo likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Did you try oiling it? :D
    Sorry. Can't help myself sometimes. :oops:
    kithmo, lvidmar and Mendel Leisk like this.
  8. UltraJetRefill
    156
    93
    Tucson, AZ
    Good call. Going to try that today.
  9. UltraJetRefill
    156
    93
    Tucson, AZ
    Sadly, I did. ;)
    jerrymildred likes this.
  10. padroo
    2,763
    2,252
    If the dipsticks are the same try swapping them, just an idea.
    UltraJetRefill likes this.
  11. UltraJetRefill
    156
    93
    Tucson, AZ
    Yep, going to give that a go in a day or so. Dipsticks are only US$12 or so, so if it's a little rough I'll probably just buy another. If it's the tube, I'll just live with it.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    See post #5 :rolleyes:
    krmcg likes this.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I can tell you from experience the dipsticks between Gen 3 and Gen 4 are the same. The tubes are bent slightly differently. There are boltholes cast into the block. The Gen 3 uses the outer (crankshaft) side hole to bolt to, and the Gen 4 uses the inner hole to bolt to. I would even guess that any car that uses the 2ZR engine design has the same dipstick.
  14. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    Ours has become easier with time. It was sort of rough at first.
