O'Canada
Discussion in 'Gen 3 Prius Main Forum' started by 2013 Prius/FR-S, Jul 21, 2013.
  1. 2013 Prius/FR-S
    2013 Prius/FR-S New Member
    Just purchased a 2013 Prius Plus Canadian edition. The rebate on the plus is currently $3000 off that model:)
    I work for Toyota and wasn't on planning on getting another car to use my discount again in January. Anyway the plus in Canada is quite different then the US model the only thing that doesn't make a base model is the 17" rims and a very subtle skirt package. I was wondering if there was anyone else that found value in the engine block heater you can purchase for the not so hard starts in the winter time.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There generally isn't a net savings. The purchase of the heater plus the cost to heat the engine and generally it is on longer than it needs to be, so it can be wasteful, rarely adds up to the savings of the warmup cycle with the engine. But if you want higher gas mileage and are willing to trade a slight increase in electric costs, then why not?
    The Prius like all cars with cats needs to heat up the catalytic converter or else it is useless. Most cars including the Prius run rich and hotter until it is warmed up, and then start running normally. In a 15mpg vehicle, it is not really noticeable. In a 50mpg Prius, you get mid-30's to low 40's during the warmup cycle until S4 (Stage 4) is reached when everything is up to the correct temperature and the Prius is operating normally. In climates where it is really cold and the engine is cold, this takes longer. This is most evident in short trips. If it takes 2-3 minutes to warm up and you only have to go 4km, then the car may just warm up by the time you turn it off. So you will be getting mid 30's to low 40's mpg. That's 6.7 to 5.2 l/100km. But once you are up to temp and you can drive around normally, you will be getting mid 50's which will slowly drag your average up, or in your case low-4l/100km and drag the average down.
    2013 Prius/FR-S likes this.
  3. enigma88
    enigma88 Junior Member
    34
    Alberta, Canada
    Just curious, if you don't mind me asking...how big is the employee discount for Toyota?
  4. 2013 Prius/FR-S
    The discount depends on the vehicle the more money the bigger discount
    We get $1000 below dealer cost, the prius would have worked out to $333 48/month lease that includes the already off $3000.
    The $3000 off right now on that model and since I was buying a second car in less than 2 months they gave me the car as a "family discount" which works out to $800 above dealer cost.
    The cost over the next 48 months will be $387 48/months
    I did this because this particular package will be lifted very shortly and I thought the discount was substantial enough that if I wanted out of the car it would be easy enough to do as a base lease would cost $473.81 on a 48 month term
    The Prius and FR-S both work out to $2750 off give or take $10
    My discount just would have made it that much sweeter, they also dropped the FR-S rate 1% last month which works out to about $30 per month. I will likely get out of the FR-S next year and lease another one as long as the rate stays down
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    For your original question, I found the block heater pretty much non-effective in Edmonton on the GII. I got a GIII without it (in Alberta) which is supposed to be not possible. It would be a waste of money in my opinion. The Prius has no trouble starting with a 20 HP starter motor and a 200V battery boosted to 350ish volts! When it's cold enough to -need- a block heater on other cars the wimpy one provided has no effect. You need at least 600W for a block heater to be effective when it's cold enough to need it. The one provided is half that.
