OCC installation finally!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ivanhoe, Aug 1, 2023.
  1. ivanhoe
    ivanhoe Member
    66
    26
    2015 Prius v wagon
    Finally got around to install my Rulline OCC after a sneak peak under my throttle body. With 161k km on the vehicle there was evidence of oil at the bottom of my air intake. I ought of not pulling the intake at this moment even after I bought my gasket but I installed a new PCV valve. I made my own holder for the OCC and took a few pictures.
    #1 ivanhoe, Aug 1, 2023
  2. ivanhoe
    ivanhoe Member
    66
    26
    2015 Prius v wagon
    the final appearance
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Good on you!
    No rattling when the engine fires up and shakes the most? I'd change out those hoses for some heavier wall fuel line hose though.
    Tim Jones and ivanhoe like this.
  4. ivanhoe
    ivanhoe Member
    66
    26
    2015 Prius v wagon
    No rattles, just been proactive. The hoses are the thick ones, there wasn't any of the black ones available. I'll keep a eye on them.
  5. Mendel Leisk
    38,726
    SAE30R7 (or SAE30R6) is the usual fuel line spec. You should be able to buy by the foot at any automotive specialty store. If you cut the orig PCV hose and push on barb (or PEX) splicers at the cuts, you can plumb the whole thing with 3/8” ID. Clamps are not required, actually are detrimental, at barbed connections.
    ivanhoe likes this.
  6. John March
    John March Junior Member
    26
    Winston Salem NC
    2014 Prius v wagon
    Great Work. I've been debating the best way to run the hoses without fouling up the air box. Ultimately gave it enough slack to stay below the lowest airbox mounting point and ran up in front of the inverter. I'm using the braided hose as well.
    Looks great.
    ivanhoe likes this.
  7. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    When it's cold the oil and moisture in it looks like blown head gasket.... so don't be alarmed when you check it....
    ivanhoe likes this.
