Tags:
  1. Noahdoge
    Noahdoge Active Member
    165
    119
    Mississippi
    I’ve had issues with a fuel smell coming from the cabin air ever since I’ve installed the OCC. I’ve replaced the gaskets and added thread sealants. Any other ideas before I completely do away with it?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Maybe your hoses are somewhat permeable to the fuel/oil liquid/vapors?
    Are you sure your hoses are clamped and providing a good seal on all of the fittings?
  3. Noahdoge
    165
    119
    Mississippi
    I got Goodyear fuel line hose that said it was oil resistant rubber reinforced with woven polyester. I checked all the fittings and connections.
  4. xliderider
    7,869
    3,116
    Honolulu, HI
    Does your OCC have a dipstick? I put a small o-ring under the threaded portion of my dipstick because I didn't think it was vapor tight.
    I have subsequently removed the dipstick and replaced it with a stainless steel cap screw, again with the o-ring.
  5. Mendel Leisk
    38,702
    Get something that can pressurize (or vacuum) the system, check for leaks?
    A fluid transfer syringe?
