Occasional cylinder misfires when cold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheLandYacht, Dec 3, 2020.
  1. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    3 times in the last month (incidentally, it's been since the weather started getting cooler) I've had the Prius pop a P030(#) code within a minute or two of first starting the vehicle. I clear the code & it doesn't come back...for a bit over a week or so.
    Never the same cylinder twice.
    The car drives fine once it warms up (which I let it get over the 100f mark before I take off).
    Anyone else experience this?
  2. Mendel Leisk
    42,101
    How many miles?
    Ever cleaned EGR/intake?
    Coolant level stable?
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Bad head gasket
  4. ETC(SS)
    7,395
    Before the EGR - head gaskets issue became the major cause of death among G3's there were reports of G3's sputter-clang-banging on cold mornings that do not appear to be EGR related.
    OTOH.....
    If I drove a G3 - which I DO (I'm on my second as a company car, and the first one is still in service) I would check the EGR FIRST.
    Good Luck!
  5. Mendel Leisk
    42,101
    Leak down test is good to determine if-and-how head gasket is leaking.
  6. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    130k(ish)
    EGR/Intake not cleaned (only had it a couple of months, it's on the list as soon as I get a little extra $$)
    Coolant level's right where it should be
  7. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Here's hoping, and thanks for the advice.
    Also, looking at your Rating...thanks from a fellow (former) Bubblehead.
  8. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    OK. After doing a little light reading...
    No visible oil in the coolant
    There was no coolant mixed into the oil when I changed it a couple of months ago
    Other than those codes, and ONE incident of the dreadful-sounding just-started clatter...it runs smooth as butter. Even on the days when it threw a code, I didn't hear much in the way of hesitation, knocking, etc.
    Backstory on that, wife had started it to move it across the yard & shut it off the morning before. That clatter when I started it up to go to work scared the be-jesus out of me.
    Looking at what it takes to do a leak-down test, I'm not sure I'm up to this. I'll probably take it to a professional.
  9. jas8908
    jas8908 Member
    42
    38
    dallas
    About how many minutes did the clatter last?
  10. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    I wasn't familiar with it at ALL...so it lasted about 1 second (long enough for me to reach for the key & shut it off).
    Next afternoon, after it'd had a chance to warm up...and I'd had a chance to read a bit about the Clatter, calm my nerves a bit, etc...it lasted 3-4 seconds before it settled out & sounded normal.
  11. jas8908
    jas8908 Member
    42
    38
    dallas
    That’s nothing to be concerned about. Still happens in cold weather sometimes with mine even though I cleaned the complete egr system, IM, throttle body and installed a catch can. Part of the Prius experience. :)
  12. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    And every vehicle has its learning curve. You wouldn't believe how much crap I had to learn about "German diesel" vehicles when I bought my Sprinter (new off the lot) back in 2005.
    By the way, this (and a string of large vehicles before & after it) are where the "The Land Yacht" nickname comes from.
  13. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Whoever suggested it might be EGR...looks like you may have been right.
    Tonight, on the last leg of my nightly commute (40 miles each way), I start climbing a (rather small) hill & the car started shaking violently. Let off the gas & the shake immediately went away.
    After a few seconds, it seemed to go back to normal.
    I checked for codes (no CEL on the dash) & found this.
  14. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
