Occasional severe vibration on highway
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jonb505, Dec 24, 2014.
  1. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    82000 kilometres on my 2012 v. 16 inch wheels. Serviced at the dealership right on schedule since new. Last service at 80000 they said the tires are at 2/32 tread depth and recommended replacement. Michelin energy savers, original tires. My monthly driving is only around 600 km so I decided to wait till the spring to change them.
    Have had this happen twice now, first time 1 month ago, and happened again this morning. Both times driving straight on the highway around 85kmh, steady accelerator pressure around 75%, but letting off the gas or pressing harder made no real difference.
    The car just starts vibrating very badly feels like the tire is About to come off(or if you've ever experienced it, feels like there is a bit of water in the tire, making it hammer, vibrate severely).
    Steering feels fine. Feels like coming from left side, front end. The vibration only lasts 20 seconds, slowly increasing in severity for 5 seconds then fading just as fast, and feels normal and smooth. Both times on different stretch of road, smooth pavement.
    Only thing I can think of is maybe a rock or something gets stuck in the tread and then shakes itself loose after a few seconds on the highway? Could it be something else, wheel bearings? Or my worst fear, something wrong with the HSD? :unsure:
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Its a bad tire. I'd suggest having them re-balanced and if that doesn't fix it - replace them.
  3. mikefocke
    3,902
    1,758
    Sanford, NC
    With all the rain you get in Vancouver, I'd be changing the tires now. I'd also get an expert to look at the front end bearings.
    Tread Depth Matters
    I'll cheat and just give you the results from a TireRack testing session. The difference between a new tire and one worn down to 2/32 (legal limit in many US states) in a test on a water soaked surface was an almost doubling of stopping distance! 4/32 deep tires took about 50% longer to stop than new tires.
    New - 195 feet
    4/32 - 290 feet
    2/32 - 378 feet
    Even more startling to me is that on a 2/32 tire, in stopping tests in the wet from 70MPH the new tire would have stopped the car where the worn tire would only have slowed the car to 55MPH!!!! 4/32 would only have slowed the car to 45!!!!
    They don't cite skidpad tests but the same issues that affect stopping distance would affect your staying on the road as you round the curve in the very wet. The tire needs the depth in order to evacuate the water beneath the tread and get the tire "rubber" into contact with the pavement. If it rides up on the water, it is like driving on ball bearings. I recall driving behind a car once and seeing it hit a puddle just as it came to a bridge and then going off like a pinball bouncing off both the sides of the bridge. When I stopped, sure enough he had balding tires.
    Measuring Tread Depth
    Measure in 3 places across the width of the tire. The lowest depth is the one you use in comparing tread depth. You can find the original tread depth in the "specs" area for each tire at Tire Rack. Their home page has videos showing how you can measure using a coin and what the recommended tread depths are and how they affect handling. Or you can buy a "professional" tread-depth gauge from most auto parts stores for around $3.
    Mendel Leisk and jonb505 like this.
  4. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Thanks for the tips and suggestions. My average speed in daily driving according to my trip information screen is around 25kmh. Lots of slow, lazy, stop and go traffic. Very little opportunity to get dangerous driving at those speeds. And if it snows I stay home. :)
    I'll ask about the wheel bearings next time i'm in for service. I did a google search in the meantime as i'm certain this could happen to any car or truck as i suspect it to be a tire, suspension issue.
    came up with this of all things on a ford truck forum: Random Front End Violent Vibration at Speed - Ford Powerstroke Diesel Forum
    this describes my car's symptoms exactly. I suspect now it may be tire pressure from reading that thread, or at least thats the cheapest thing to check first! I normally have run 42f/40r tire pressure most of the life of these tires and at my recent service they set the tire pressures back to factory setting, which is when the random vibration started happening.. :cautious:
  5. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Radial tires can have an assortment of issues that produce an equal assortment of symptoms relating to vibrations. Even balancing problems can cause intermittent vibration, especially if more than one wheel is involved. And lets not forget that those were super cheap tires when new. They are not the same as the Michelin Energy Saver-AS tires that many of the Prius owners use.
  6. Mendel Leisk
    40,584
    You've put 82000 kms on a set of tires, and you're running them at less than legal minimum tread depth. Heading into winter. C'mon, do the right thing, for anyone who shares the car with you, and vehicles that share the road with you.
  7. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    actually they are the "All-Season" michelin energy savers, not the other ones you get in the US. Maybe just in canada we get the energy saver AS from the factory?
  8. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Hard to say, but OEM tires are generally of cheaper construction than retail, even if they have the same name on the sidewall. In any case, the tires are your first and best bet for the cause.
  9. GregP507
    GregP507 Senior Member
    3,002
    481
    Bad harmonics, probably caused by several wheels being slightly out of balance. At certain speeds and relative wheel-rotational positions, the vibrations resonate with each other, making it much more noticeable. That's my guess.
  10. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Alright I'm pretty sure it's the tires as everyone is saying, not going to investigate any other possibilities. Obviously they are worn out. And for the sake of my fellow drivers in the lower mainland I'll get some replacements ASAP. (y)
    now just gotta find a deal on a set of Michelin energy saver AS.
    I didn't know that about oem tires rdgrimes, if that's the case then I have high expectations for my replacement michelins. These ones have been pretty good overall, although they have had balancing issues occasionally from the beginning(maybe a result from said cheaper construction).
    Tideland Prius and Mendel Leisk like this.
  11. Mendel Leisk
    40,584
    You might also consider Michelin Premier A/S, if only because the Energy Savers are hard to even find, locally. The Premier's almost certain to give up some mpg (vs Energy Savers), but are very good for traction, stopping distance. Premiers are in stock at Costco, for one. Unfortunately, the Michelin promotion, $70 off on set of 4, is over for now.
  12. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Another cause of severe vibration is a blown shock absorber but those are nearly continuous once above a certain speed and don't typically fade in and out at a constant vehicle speed.
  13. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    "Balancing issues" are generally tied to the person doing the balancing, but there are cases of improper radial run-out that can mimic bad balancing. That's essentially a "lumpy tire" issue caused by sidewall or tread construction problems. Its a more common problem on tall tires like 4x4 tires.
    I might agree with others that in a cold climate there might be a better all-around choice than the ES-AS, but there's no better choice for MPG.
  14. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I agree, except would replace the phrase "resonate with" with "reinforce" (i.e., the imbalances are additive) at some certain orientation of wheels relative to each other. Then several seconds or a minute later when those wheels are 180 degrees from that relative orientation (due to one turning very slightly faster than the other), the imbalances will cancel each other. Then the cycle repeats ... .
  15. GregP507
    3,002
    481
    Resonance - Wikipedia, the free encyclopedia
  16. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I'm quite certain I want the energy savers again. Old ones have served me well providing adequate traction for my driving needs and great MPG. Had to do one panic stop on the coquihalla a year ago in the summer, deer jumped out on the road, I was doing 120kmh, slowed enough to steer around the animal full brakes applied. Couldn't want for a better tire. I even drove them through one Edmonton winter before I moved out here to the coast. Sure, the stability control, TCS, ABS got a good workout but they performed predictably in severe winter conditions although very little grip as expected in extreme cold.
    Perhaps I should take a trip across the border and pick up some energy savers. I believe the tires in the 16" Prius v size are made in USA so perhaps duty free? (y)
  17. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    On second thought, after looking up some prices online, and considering the low annual kilometers I put on my v, perhaps the energy savers may not be my most economical choice, $ per km. i'll look into the premier A/S. Any other recommendations?
    Thanks.
  18. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Not an easy calculation. For me, the gas savings (compared to OEM tires) from the ES-AS amounted to about 1/2 the entire cost of the tires over their projected life. But that was at $3/gal for gas with a 4 MPG boost from the ES-ES.
    Anyways, be sure to include fuel savings into your numbers.
  19. schmuly
    schmuly Member
    209
    51
    BC
    We have bought tires in the USA and brought them back to Canada many times, only paid the HST on them. Some were installed and some were loose. Some places in WA. you can ask for tax exempt, show D/L to prove you are from BC and save some $$.
  20. Tideland Prius
    16,445
    I thought that's only for residents of provinces/states that do not collect provincial/state taxes?
