October 2006 MPG Average
Discussion in 'Gen 2 Prius Fuel Economy' started by Tideland Prius, Oct 17, 2006.
  1. Tideland Prius
    16,159
    Total Mileage: 36363.7km
    Tank Mileage: 604.1km
    MFD Avg: 4.4L/100km
    Calc'd Avg: 4.64L/100km
    Price per litre: 92.9¢
    Fuel Cost: $26.21
    Fuel Added: 28.058
  2. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    Total car miles: 2160
    October miles: 440 (Still working on this tank)
    Current tank MFD AVG: 72.0 MPG
  3. Tideland Prius
    16,159
    Total Mileage: 37081.2km
    Tank Mileage: 717.5km
    MFD Avg: 4.4L/100km
    Calc'd Avg: 4.48L/100km
    Price per litre: 93.4¢
    Fuel Cost: $30.00
    Fuel Added: 32.117
  4. santoro1
    santoro1 New Member
    132
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 26 2006, 09:03 PM) [snapback]339006[/snapback]</div>
    total miles on car 2100....4th tank of gas...First three tanks 52.3, 52.7, 53.4 This tank with 3 blips left, over 400 miles so far averaging 56.3 according to MFD
  5. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    October numbers:
    miles 1907.4
    gallons 39.777
    MPG 47.9523
    see my last post in the 45mpg lifetime!
  6. troe
    troe New Member
    83
    Total miles on my Prius 7500
    October Tank 604.4 Mi, 9.82 Gal
    61.5 MPG
    50% Hyway at 60 MPH, 50% city at 35-40 MPH
    :D
  7. anthony.pray
    anthony.pray New Member
    29
    Oregon City
    :unsure:
    I'm i little scared this last 2 tanks i have bin getting low miles per tank.
    32 MPG
    i just filled up 10.5 gallons and only got ~342 mils out of it
    i live in the grater Portland OR. during the sumer i used the AC and i am using the auto AC now
    after the car defrosts in the morning. i keep it at about 69-72 degrees or so.
    in the summer i was getting about 480-500 Miles per tank or about 47- 51 MPG.
    has any one had any MPG this low?
  8. Tideland Prius
    16,159
    I got 40mpg during my first winter. After that, it's been increasing! Even this autumn so far, I've been able to maintain >50mpg.
    Be patient, practice and reap the rewards when spring rolls around!
  9. kDB
    kDB New Member
    241
    Fenton, MO
    Date: 10/08/06
    Total Miles: 17778
    Tank Miles: 498
    MPG: 63.7
    Avg. Temp: 63.8°F
    Date: 10/19/06
    Total Miles: 18304
    Tank Miles: 526
    MPG: 60.5
    Avg. Temp: 51.8°F
  10. Tideland Prius
    16,159
    Dang, still at 60?!?
  11. kpauley
    kpauley New Member
    149
    Gilroy, California
    Well, this kind of sucks. I've been tracking my mileage since day one, almost a year ago. Keep a spreadsheet on my PocketPC that syncs to my computer. Saw this thread, figured it's a good time to sync the data and then post what I've been getting. For some reason it didn't sync right, and I lost my data back to the end of September.
    Could have been worse I suppose, but I'm now missing about 5k miles of data, which is about 20% of my total mileage....
    Since I have that, I'll go ahead and add to the thread based on what I do have:
    As of 9/27/06
    20,027 total miles
    Cumulative avg MPG = 46.49
    Most recent tank MPG = 47.69
    MPG has been going up for me recently, just a little bit. I think my cumulative was up to almost 47 MPG as of today when I filled up, but since I lost the spreadsheet I can't be sure......
  12. kDB
    kDB New Member
    241
    Fenton, MO
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 10 2006, 05:02 PM) [snapback]347202[/snapback]</div>
    That was most likely my last tank above 60 MPG until it warms back up. Though I am still barely above 60 MPG 250 miles into current tank. These are MFD numbers. The temps aren't really correct either, they are just an average of the high and low for the time period. Usully I only drive at night when it's cold. I need a new job, it's killing my MPG...
  13. jamesbalch
    jamesbalch Junior Member
    71
    Northeast
    <div class='quotetop'>QUOTE(FatTony @ Nov 9 2006, 09:25 PM) [snapback]346683[/snapback]</div>
    My mileage has decreased from 53.9 MPG to 53.1 MPG during my last two tank fills. (Almost 5K miles on the car now, MPG calculated with strict record keeping). I figure it's because the weather has turned a bit cooler up here. But I have also switched from mid-grade 89 Octane fuel to straight regular 87 Octane fuel during that time period. I have read all the threads concerning peoples opinion on Octane and how a lower grade should not affect the mileage. Just to satisfy my OWN curiousity, I am going to switch back to mid-grade and see if it starts back up.
    If it increases, then I will have to decide if the more expensive gas is worth a measly 1 MPG! With my luck, a warm period will come along at the same time and I won't know if which one turned the trick. :( I suspect the cold weather is doing it.
