Odd AC behavior
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cadenza, Jun 12, 2015.
  1. Cadenza
    Cadenza Member
    124
    LALA Land
    I just came back from a 3000-mile road trip, hopping National Parks in Utah, Wyoming, Montana and noticed something odd about the AC operation. It first happened after 3 hours into the drive from SoCal to Vegas, the AC performance gradually dropped during the long uphill climb to Baker. The outside temp was only 87-92*F. The AC air slowly lost its cool and the amount of air blown out the vents was also weaker. The SOC of the traction battery was at 4 bars and sometimes dipping into 3 bars. After 20 minutes, I decided to turn off the AC and rolled down the windows. Shortly after I took a 15-min break and did a visual of the engine bay... nothing seemed out-of-order.
    Continuing with the drive I turned the AC back on and it worked normally. From this point on, I routinely turned off the AC for 10 minutes for every 45-60 minutes of operation or when heading up long steep hills with the SOC falling into 3-4 bars. It worked fine this way for the entire trip. I noticed the AC performance didn't suffer if the car wasn't going uphill and the SOC was above 4 bars. There were a lot of hill climbs during this trip and I thought the traction battery would crap out since it's 138k old. In Yellowstone, the SOC oscillated between 1-2 and 8 bars a few times a day due to the hilly terrain. But the Prius made it to the top of Beartooth Highway at 10,947 ft... slowly but it made it!. On the way back to SoCal, after descending the Cajon Pass, I kept the AC constantly on for the last 3 hours and it worked fine. No more hills or passes to climb I guess.
    Has anyone had a similar experience? Does the ECU back off the AC load when the traction battery is way below its optimal SOC and the ICE motor spinning at full tilt during long hill climbs?
    Beartooth Hwy
    Traffic Control in Yellowstone
    #1 Cadenza, Jun 12, 2015
    Peter Lipovský likes this.
    49,735
    i think you nailed it. how many miles on her?
  3. Cadenza
    Cadenza Member
    124
    LALA Land
    140k by the time I got home.
    I hope my theory is correct since the AC compressor is electric.
    49,735
    right, there are many threads here on mountainous driving, i wouldn't be surprised at all. plus, with 140k, your battery is like a 60 year old man trying to run up pikes peak.:p
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    damn that snow looks good. it was 97f today and humid.
