Odd air conditioning problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Karamarika, Aug 26, 2016.
  1. Karamarika
    Karamarika New Member
    Modesto, CA
    Recently I have had a problem with the air conditioner in my 08 Prius. When I first drive the car, all is well. When I stop somewhere, then come back to the car, the air conditioner will not come on. It will still show on my display that it is on and I can pick different settings, even though the different settings do not make anything happen. Sometimes I can turn the car off and on again a couple times and the AC will kick on. Today I just decided to drive with the windows down, and after 10-15 mins, the AC kicked back on.
    It is still running cold when it is working, so that has not been an issue. So far it has always worked with the first start of the car and has not stopped working once it is working. Please let me know what you all think might be the problem and here's hoping it doesn't cost a fortune. Thank you!
    49,726
    welcome! is there warm air coming out, or no air at all?
  3. JC91006
    16,496
    8,406
    There was a member here that had a similar problem with the AC not turning on, he found a loose wire by the glovebox where the cabin filter is located.
  4. Karamarika
    Modesto, CA
    No air at all but when it does finally kick on, it is cold air.
  5. Karamarika
    Modesto, CA
    Thanks, I will check that out and see if the same is true for my car.
  6. bisco
    49,726
    this is usually a fan issue. look for threads on removing and testing it.
