Odd piece of plastic in my glove compartment
Discussion in 'Gen 2 Prius Main Forum' started by EmptyG, Aug 20, 2006.
  1. EmptyG
    EmptyG New Member
    39
    Good afternoon all :)
    I was cleaning up my Prius (relatively new, about 2 months old or so) and was puzzled by something. The "top" glove compartment had a rectangle piece of black plastic in it. It wasn't connected to anything, and doesn't seem like it belongs in there. It was just laying in there.
    Am I missing something? Is this actually to something or is it just a leftover piece of something? It does have some little ridges on the side, indicating it might connect to something.
  2. ohgreys
    ohgreys New Member
    123
    I believe you have found the shelf that is supposed to go in there. Look closely inside the compartment and you should see pieces of plastic (possible molded to the sides--I can't remember off the top of my head) that the shelf either sits on or slides into.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Yes, it's a shelf. You can use it, or leave it out as you see fit.
    Tom
  4. aaf709
    3,862
    2022 Prius Prime
    Yes, it does connect to something. It connects to the sides of the "top" glove box (there should be grooves in the sides). That turns the "top" glove box into a two-level. I keep my auto expense book in the upper portion.
    When I was driving home from the dealer, I hear an annoying clicking sound that came from the glove box. The shelf was there, but hadn't being installed correctly on one side (it was lying on top of the slot).
    EDIT: Heh, you walk away from the keyboard for a minute and see how many replies there are. :)
  5. EmptyG
    EmptyG New Member
    39
    Awesome, thanks for the QUICK replies all! :) Glad I didn't just toss the piece out.
  6. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    So has anyone figured out what to put in/on the shelves? I would imagine maps, but then wouldn't they go in the map pockets? And how about the center console & hidden drawer? I've only ever had a glove box before, so I've been trying to figure out how I'm supposed to use these nifty little hiding spots. And what about that area in the front of the center console under the armrest? There is some sort of slot that seems made to hold something, but I don't know what?
    At least the salesman did show me the slot in the back of the bottom glove box for the manual. I would never have figured that out by myself. Any suggestions appreciated. Thanks!
  7. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(PA @ Aug 20 2006, 06:19 PM) [snapback]306448[/snapback]</div>
    I've been keeping a log of my auto expenses ever since I've owned a car. I keep it, with a pen, in the uppermost self. Other pieces of paper I would like to have (the channels of the XM radio, for example) goes right beneath that.
  8. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    tire gauges
    pens
    OBDII widget for the laptop
    valet cards, not that they'd ever see the hands of a valet...
    _H*
  9. RichBoy
    RichBoy New Member
    189
    its a shelf. its very handy too. if you have trouble installing it, just drop by your Authorized Toyota Dealer and they will put it in for you very quickly.
  10. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    The fit may have been improved since 2004, but mine would come loose. It was fixed by putting a layer of electrical tape into the grooves on the shelf and then sliding it into place.
  11. Autosmiler
    Autosmiler New Member
    52
    <div class='quotetop'>QUOTE(PA @ Aug 20 2006, 08:19 PM) [snapback]306448[/snapback]</div>
    What do you mean by the "hidden drawer"?? I thought I found all the secret spots! Seems like you mentioned all the containers I knew about, except for that "hidden drawer". Do you mean the one below the CD/radio tuners? The one that opens like a jaw? There's a pack of gum in mine in that area, plus a pen and sticky note pad for tracking mileage and MPG for every gas station stop.
    The only real "drawer" i can think of, where you pull a thing out, is the one under the center console (where females can put their ::ahem:: stuff for emergencies... :blink: TMI? sorry lol). Someone once mentioned on another thread that that's where they hide their "stash", whatever that means :rolleyes: . Others put their maps in there instead. Just some ideas for you.
    On the little top shelf, I put travel size instant hand sanitizer and travel moisturizer. It's probably good that you don't have that much in your storage spaces b/c it'll keep your overall carrying weight down -- you know how we Prius drivers are obsessed about maximizing MPG! *SMUG ALERT* B)
  12. Tideland Prius
    16,530
    Upper:
    top shelf - touch-up paint, swiffer cloth, screwdriver
    bottom - fold-out maps, tyre pressure gauge, band-aids, scissors
    Lower: owner's manual in shelf, mp3 player, hand sanitizer
    drawer - tissue box
    centre - CDs
    door pockets - map, sunshade, gloves, microfibre towel, water bottles.
  13. molgrips
    molgrips Member
    199
    I dont' have a shelf in my upper glovebox...
    It does contain parking vouchers, a bird-book, my car pass for work and some screen wipes.
    Centre console - sweets, phone charger, CDs, de-misting pad
    Under centre console - sunglasses (out of sight of thieves)
    Lower glovebox - locking wheelnut key, manual and not much else
    I do have an annoying rattle coming from the glovebox area though - dismantled it and the surrounding heater vents, but found nothing.. :(
  14. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Autosmiler @ Aug 20 2006, 10:43 PM) [snapback]306579[/snapback]</div>
    The "hidden drawer" is the one in the center console. It's called the "hidden drawer" as it's generally the last one found. :D I keep my portable XM radio there (unless it's in use).
    I keep my mileage log and XM radio information in the upper glove box. General Prius information, menus, chop sticks, iPod and the like go in the lower glove box. Center console has stuff for work, casino cards, audio stuff, MFD cleaner, tire gauge and tools. The manuals go in the pouch behind the passenger. The door panels hold a book on my side (current reading material) and my wife puts anything she wants on the passengers side. The drawer under the radio holds the remote for the XM radio, my name tag for church, a Swedish Christmas Goat and the button to operate the BT override.
  15. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I keep my micro-fiber cloth for the MFD on that shelf. Gas receipts go on the shelf in the center storage box. I use one of the cup holders for quarters since a have to do meter parking at one of my jobs, and my water bottle is too big for the cup holder. I still don't have a use for the "hidden" drawer. Maybe I'll put my weed in there ;)
  16. ramarren
    ramarren New Member
    96
    San Francisco Bay Area, California
    I had the same question about the plastic bit, figured it out last night.
    I am very happy having all these storage compartments. My last car's compartmentalized interior storage really came down to two large compartments in the door bottoms, which rapidly became a mess of stuff piled in helter-skelter. With the Prius, I have all the little bits and pieces stuff that I like to have in the vehicle all the time neatly stored and easily findable, and there's nothing on the seats or in view when the car is parked. That's a plus to me. :)
    Godfrey
  17. Dripps
    Dripps New Member
    116
    Northern NJ (Sussex Co)
    <div class='quotetop'>QUOTE(molgrips @ Aug 21 2006, 05:43 AM) [snapback]306609[/snapback]</div>
    I had an annoying rattle and swore it was coming from the glove box. Turns out it was my sunglasses in the upper eyeglass holder!! Sounds are often hard to track down.
  18. qbee42
    18,058
    3,079
    Northern Michigan
    <div class='quotetop'>QUOTE(PA @ Aug 20 2006, 09:19 PM) [snapback]306448[/snapback]</div>
    I keep a little plastic basket on the top shelf, which contains a cleaning kit for the MFD - one of those LCD cleaners made for notebook computers. In the lower box I have the Prius manual, a tire gauge, and a swiffer for getting the dust off of all that black plastic.
    Tom
  19. santoro1
    santoro1 New Member
    132
    <div class='quotetop'>QUOTE(EmptyG @ Aug 20 2006, 08:26 PM) [snapback]306421[/snapback]</div>
    I had the same thought at first..What is this little piece of plastic..I happened to see the slots and tried it out..Not very tight..I put pad and pens and tire gauge on the top shelf.. tissues and microfiber cloth under the shelf..In the lower compartment, car manual, receipts, and workout gloves...In the middle console coins in a smaller change organizer, head phones for working out, bluetooth ear piece for cell phone and extra pieces to the Belkin cell phone holder (it fits in one of the cup holders) and garage door opener...under the radio breath mints, hand sanitizer and contact lens solution..
    BTW I also found two rubber plugs in the glove box that were not installed under the car...Thanks to PC, I knew where they were to be installed and easily accomplished it...
