Odd random failures. 12v going dead?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by created, May 23, 2015.
  1. created
    created Junior Member
    Arkansas
    Power steering out, all gear lights and fuel gauge blinking simultaneously, abs light on, flat tire light on, windows won't work (except driver side still works), display not showing any data,
    Everyone else works though. I can start the car and drive except it's hard to steer without PS.
    There's no triangle or engine codes. I have a scanguageII. It shows nothing out of ordinary. SOC is 55%. I also put the car in diagnostic mode and it shows no codes or errors there either.
    I'm just stuck with no ideas except that I've read things start to go crazy when a battery is going dead.
    Any suggestions would be greatly appreciated. Thanks much!
  2. JC91006
    16,673
    8,518
    Some of those symptoms seem to be 12v related. But the power steering not working is a completely different issue. I would change the 12v first if it's over 5 years old.
  3. Patrick Wong
    18,200
    6,493
    A question: Did all of the symptoms appear simultaneously or did they develop over time?
    I have two ideas:
    1. Measure the 12V battery voltage both when the car is IG-OFF, and when it is READY.
    2. Get Mini VCI so that you can retrieve the DTC logged by your car. I guarantee that fault codes exist if the ABS light is on.
  4. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    My 12v battery lasted just over 4 years. Then it was as if my Carmine was possessed! Changing the 12v corrected -- exorcised the demons, lol.
    I agree with C91006. the power steering is a separate issue. Start with the 12v and perhaps you will get better diagnostics once that is resolved.
    #4 Freedom, May 23, 2015
  5. Mendel Leisk
    40,584
    Excise 'em, dammit. :ROFLMAO:
  6. Freedom
    535
    69
    Northeastern MA
    Yep, typo, fixed it now ha haa.
  7. created
    Arkansas
    It happened all at once. Like a light switch and all the sudden steering was hard and noticed dash screen was void of info. image.jpg
  8. created
    Arkansas
    No telling how old the battery is but its a yello top. I believe one that optima made specifically for the prius. Shows quite a bit of corrosion on the ground connecting post.
  9. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    never had one take out the power steering ..how is the blinker fluid? has it been changed in the last few weeks?
  10. bisco
    51,154
    corrosion is a bit unusual, i would replace it. any water in the battery area?
  11. Patrick Wong
    18,200
    6,493
    Regarding the power steering system, check the following two fuses: 7.5A ECU-IG and 50A EPS.
    Regarding the combination meter, check the following three fuses: 10A GAUGE, 15A DOME, 7.5A IGN.
  12. created
    Arkansas
    Got it fixed. Took a new 12v Batt and thx to Patrick I checked fuses and there was a blown 7.5a ECU-IG fuse. I changed the batt 1st and then replaced fuse. The fuse was probably the culprit of all the sudden & simultaneous failures, but also the 12v Batt was getting down low enough that it was time to be changed. Anyways I'm back on the road again (this time with spare fuses abord.
    & Btw this is on a near 250k mile car. When you're rolling with this many miles and something goes out... It could be anything lol
    Thx for your help and suggestions guys!
    I appreciate ya!
    Dino33ca likes this.
  13. Mendel Leisk
    40,584
    Hope so. The only thing, when I hear fuse blow, I think: how come?
    Knock-on-wood it's all good. :)
    Patrick Wong likes this.
  14. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Fuses do sometimes fail on their own. Nothing is perfectly reliable. If there was a cause for the blown fuse, it will happen again.
    JeffD
