Odd whining noise related to brakes, new 2015 Prius Five
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PetesPrius2015, Apr 4, 2015.
  1. PetesPrius2015
    PetesPrius2015 Junior Member
    Benton City, WA
    Today as my wife was pulling into the garage I heard a fairly loud, intermittent "screech" or whine coming from under the hood. I had her turn off the car, then start it again -no noise. Then I had her back out and pull back in, heard the noise. "It happens when I press on the brakes" said she. I had her do so, and, sure enough, there it was. No noise when the pedal is depressed, but as soon as the pedal is let off, the noise cycles on for a few seconds and then stops. I figure it's some sort of brake booster pump going bad. I was quite crestfallen because we have only had the car for 2 weeks and like it so much. Anyone know what this is?
    Thanks!
  2. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Does it happen under any conditions, or usually when it's wet? Mine squeal sometimes as I pull into a parking space if there's rain. If so, then I don't think that's anything to be concerned with.
    49,469
    is it the vpns?
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Does it make the sound while standing still? If so and it's repeatable bring the car in and demonstrate it to the service writer.
  5. Mendel Leisk
    38,717
    When the car's been sitting some time, off, open the drivers door. Do you hear a whirring noise for a few seconds? Is your problem noise similar? The car invariably does this sound when you first open the drivers door, and then intermittently thereafter, as you're driving. It's pressurizing the brake hydraulics, somehow. Could be that?
  6. PetesPrius2015
    Benton City, WA
    Thanks everyone who took the time to reply. The noise is certainly some kind of brake hydraulic pump as it only happens after the brake pedal is depressed and released. The plan is to take it to the dealer and get their take on it. I think it might be "normal" noise but inside our garage it almost sounds like grinding metal to me. Therefore my concern. I'll write back when I learn what they say.
  7. bisco
    49,469
    thanks for the update, all the best.(y)merged. btw, the o/m has a section on all the prius specialty noises.:)
    #7 bisco, Apr 6, 2015
  8. Former Member 68813
    3,524
    981
    US
    if the noise is of any concern, the OP should be able to replicate it, record it, and post the recording.
    #8 Former Member 68813, Apr 6, 2015
  9. PetesPrius2015
    Benton City, WA
    Updating topic 4/21/15: noise seems to have disappeared. Cannot reproduce the noise so I guess it fixed itself - or maybe it was paranoia on my part. Thanks all for taking the time to respond!
