odometer disconnection
Discussion in 'Gen 2 Prius Main Forum' started by k4141222, Nov 4, 2005.
  1. k4141222
    k4141222 New Member
    how do tou disconnect the odomerter
  2. LaughingMan
    LaughingMan Active Member
    1,386
    Marlborough, MA
    What? :huh:
    Are you going to ask us if running the car in reverse takes miles off the odo next?
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Running a car in reverse not only doesn't roll back the odometer, it seems to cause the car to launch itself backwards out a second-story window of the garage. It's true! I saw it in a movie.
    Save Ferris!
  4. jeneric
    jeneric New Member
    442
    Redmond, WA
    This also really destroys your MPG numbers. Obviously uncomprehensible in this forum.
  5. KTPhil
    KTPhil Active Member
    1,379
    Email Toyota and tell them what you have in mind. I'm sure they'll help you with your problem. They'll probably advise you to pull out those fat orange cables.
  6. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :rolleyes: [Chuckle] Disconnect WHAT? the odomerter ?? I'don't know what an "odomerter" is.
    This is one of those questions which would elicit the old computer password question: "If it was possible and I told you, I'd have to shoot you !!"
  7. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    If you were to disconnect it the car wouldn't start.
  8. ScubaX
    ScubaX Member
    484
    Redding, CA
    You'll just have to confess to Dad that you drove it. :p
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    that happened last month to a guy in Bellevue... driving a caddy and pushed an SUV off a 3rd story parking garage...hehehe...dont blame the guy, i feel the same way about SUV's
  10. aaf709
    3,862
    2022 Prius Prime
    I guess the next question is......why do you want to disconnect the odomerter (sic)?
  11. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Fraud. What else?
    It is against federal law to disconnect an odometer in addition to any state laws generally proscribing fraudulent criminal activities.
  12. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    It's sort of like a car thief logging on to ask how you steal a Prius, I guess. Hmmmm... only 1 post, and this is how he spends it? <_<
    At least he has been lurking for a long time, he didn't just sign up to ask this question...
  13. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    OK, I'll help the guy out...
    First you need the proper tools, this would include a 12cm metric Crescent wrench and most importantly a left handed monkey wrench. It's also important to have on hand a 5 gallon can of counter rotating prop wash.
    Now to get down to business. Step one is to locate the muffler belt, this is easily located as it connects the HSD muffler to the ICE muffler and syncronizes them both with the gonculator armature. You first loosen the pre-tensioner with the metric crescent wrench, then the post detensioner with the left handed monkey wrench, being carefull to loosen both devices an equal amount to avoid placing an imbalance on the gonculator armature. The muffler belt can then be easily removed. Now you can access both the odometer and evenometer connections. Both must be disconnected, disconnecting the odobeter and not the evenometer will keep miles from increasing but it will still rack up kilometers.
    Now you can replace the muffler belt in the reverse order it was removed, but be sure you first wash it in the counter rotating prop wash, being carefull to dry the belt completely to avoid dripping any prop wash on the AC battery.
    Good luck and have fun :rolleyes:
  14. hv74656
    hv74656 Member
    145
    Morro Bay, CA
    I don't even own a Prius and I know how to do this. First, look in the appendix of the user guide for "How to break federal laws in your Prius". Go to the "How to commit odometer fraud" section. (It helps to have your name and address written on a card for the next part.) The final step would be to call the police using the handy card you just made and turn yourself in.
    Really, what is the next crazy post going to be, "Can the rear cargo cover be used to hide a dead body from the police?â€. Whoever said there are no such things as stupid questions obviously never reads online forums. Also, it never hurts to spellcheck posts. :D
    As for tleonhar's method, I think that may void the warranty. Counter rotating prop wash is highly explosive and can only be purchased in Outer Mongolia.
  15. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
  16. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Actually, I think it can be found in the US too. One of the first things they did at the first air base I was assigned to was to send me after a can of prop wash. MAN, is that stuff hard to find! I never did find any, but if they asked me to get it, it HAD to be nearby!
    However... now that I think about it a little more, that would explain why I couldn't find it. I should have ORDERED some! :unsure:
  17. craigcush
    craigcush Member
    157
    Sedona, Az
  18. tullynoon
    tullynoon New Member
    57
    Port Angeles, WA
    Don't forget a can of relative bearing grease and a falopian tube to update the Nav unit.
  19. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    Oh, man, now I have to take a sick day tomorrow. Laughed myself sick...........
  20. jeepien
    jeepien Member
    165
    New Jersey
    Oh, please. This is, after all the 21st Century. You can turn yourself in on line.
    Click here for Citizen's Self-Arrest Form.
