Odometer jumps ahead 153 miles....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GeekStatus, Apr 25, 2015.
  1. GeekStatus
    GeekStatus Junior Member
    Los Angeles
    I just bought new 2015 Persona Prius..drove back to the dealer to get the complementary full tank of gas with 172 miles on it...salesperson brings the car back and the odometer jumped 153 miles to 325. I complain and they offer to bring it back to service department. So I did that today...they could not find nothing wrong...except for the fact I have an additional 153 miles on my car...any one else had this happen and what did you do?
    bertoncini likes this.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Someone took your car out for a long ride? If that were the case, you should be raising h3ll.
    Edit: are you sure you are looking at the same things? Example: first reading of mileage was Trip A, second reading was Odometer. Trip A may not have read same as odometer initially.
    fuzzy1 likes this.
  3. orenji
    orenji Senior Member
    5,884
    3,486
    You are more than likely looking at fuel range, not odometer reading. Add more gas your fuel range will increase.
    Mendel Leisk and GrGramps like this.
  4. GeekStatus
    Los Angeles
    Yup..make sense! Thanks Orenji.
  5. Mendel Leisk
    38,717
    On our 2010 when you shut down the odometer displays, for about 30 seconds. This is regardless of what you had set when the car was on. Is this still the case?
  6. orenji
    5,884
    3,486
    Not sure what you are asking?
  7. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    The multifunction display shows a number of different things. You cycle through them using the Mode and Trip buttons on the right side of the steering wheel. I suggest you press the Mode button, then cycle through with the Trip button. once you've seen the first set, press Mode again and cycle through the next set using Trip again. Some owners like to use the MTE (miles to empty) display to decide when to stop for fuel. Others use the Trip A display to keep an eye on the CONS number that shows average mpg between fill-ups and Trip B for an entire trip or vice-versa. Some like to watch the energy flow display, etc.
  8. Mendel Leisk
    38,717
    @orenji
    Do newer models still show this. I think I read else wise here, maybe.
    If all years/models DO display odo number at shut down, that's a bullet proof method, to make sure you're seeing the right number.
  9. GeekStatus
    Los Angeles
    Well Im not crying anymore about it...but it is certainly confusing but like I said....it's what kind of feedback drivers are looking for..I may have read the displays wrong...but it would be interesting to see if it ever shows up like that again.
  10. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Mendel, my 2014 still shows the odometer at shutdown, but the display doesn't stay on very long, so it's usefulness seems kind of limited. Either way though it can't hurt to cycle through the various displays to see what info is available.
  11. Mendel Leisk
    38,717
    As doubleDAZ explained, with taps of the trip button on steering wheel, you can cycle through the choices. Press-and-hold will reset the current trip (A ot B).
  12. bisco
    49,469
    my wifes '13 hycam also flases the display for about a second after shut off. her '08 stayed on for 20-30 seconds.
  13. xliderider
    7,869
    3,116
    Honolulu, HI
    Our 2011 flashes odometer reading for about a second at shutdown.
  14. bisco
    49,469
    makes no sense whatsoever.
  15. Mendel Leisk
    38,717
    2010 definitely shows odometer value for longer than a flash, maybe 30 seconds. When filling up, I shut off the car, read the value, mutter it to myself. The act of saying it sort-of burns it into short term memory for the few minutes I'm doing the fill up. Then when I get back in I can write the odo value on the receipt, and I'm good to go for my spreadsheet calc and Fuelly. Well, except:
    It used to work. Now the effing pumps up here require you to enter your bank pin number when you use a credit card. Once I get done entering that, the odo number's typically gone walky...
    But yeah, anytime I shut down it's there for 30 seconds or so. Good for the mechanics I think.
