odometer problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sernatalex, Oct 14, 2009.
  1. sernatalex
    sernatalex New Member
    Republic of Moldova
    Hello! I've Prius 2008. It's strange problem. The odometre stoped on 1772 miles, but Trip A and Trip B it's in order. What could be, I can't image. Have any body an idea?
  2. Patrick Wong
    18,200
    6,474
    Re: odometre problem
    The combination meter ECU probably has failed (combination meter includes the speedometer, odometer, fuel gauge, shift indicator, and warning lights.)
  3. sernatalex
    Republic of Moldova
    Thanks, :) I think the faster way to understand if it's true, just to change temporarly this Combination Meter ECU with other Prius. I'll be very appriciable if you help me to understand where is location of this ECU.
  4. Patrick Wong
    18,200
    6,474
    The ECU is located on the combination meter, which you can see as you look at the speedometer. If you need repair manual info, I suggest you consult the Toyota Europe website that has this available on a subscription basis.
    Toyota Service Information
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Since the car is 2008 I wonder if this is still under warranty?
    And failed at only 1772 miles?
  6. sernatalex
    Republic of Moldova
    I have purchase this car on the Copart auctions, it's was minor colision on the back left side, I have changed the left back door, wheel, and some linnig of body.
  7. sernatalex
    Republic of Moldova
    The odometer is OK now. It's was corrected the soft in the Combination Meter. As I understood, the problem was inserted during reinstallation the soft to Combination Meter from American version to European version.
    Now I'd like to return the American version. In European Version not exist the Tire pressure control.
  8. juzernev
    juzernev New Member
    Hungary
    I have the same issue. The service wants to replace the unit, what is over 900 USD here in Hungary.
    Everything works perfectly, only the odometer stopped counting. Maybe someone tried to manipulate the odometer?
    The service figured out the current odometer status, cause they wrote 75287 into the service instead 62513 (what the odometer shows).
    So it was u who reinstalled the software in the combination meter or the serivce?
    My car is european version so basically not needed to install other combination meter soft..
  9. salman2k960
    salman2k960 Junior Member
    juzernev
    How did you resolve your issue? im facing same issue, but dont know wether its software related or hardware issue.
