Odometer Security
Discussion in 'Gen 2 Prius Main Forum' started by Michael Crestohl, Aug 2, 2022.
  1. Michael Crestohl
    Michael Crestohl Junior Member
    61
    Marblehead Massachusetts
    I am new to the Prius world and am looking to buy a used one to add to my small “fleet”. One of my major concerns is the reliability of the odometer. How hard is it for some schlockmeister seller to alter the mileage? I know it is illegal. I remember back to my younger days and mechanical odometers it was “do-able” but it could be often detected if you knew what to look for. I have no idea how secure the digital circuitry is in these cars and if somebody who knew what they are doing could “spin the clock.” If it is what would a buyer look for?
    Thanks for answering my newbie questions.
    Michael
    2010 Ford Crown Victoria Police Interceptor (retired VT State Police)
    2001 Mazda Miata SE
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,962
    1,911
    NJ-USA
    For a Gen2 Prius, "all" someone would have to do is swap out the Combination Meter (speedo cluster). It's possible to rewrite the chip, but much easier to put in a different CM.
    If you are looking at a car, get a Carfax report, run the VIN through Toyota to get their service and recall history.
    Also look at wear on the interior of the car- see if that jives with the odometer.
  3. Mendel Leisk
    40,574
    Wear on brake and gas pedals, the latter in particular.
  4. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    Prius odometer correction / Prius combination meter reprogramming.
  5. bisco
    51,140
    and because the combo meter is often defective, there are a ton of used prius with replaced odo's.
  6. Mendel Leisk
    40,574
    So, 30~40 years on from the days of mechanical odometers, rolling back the miles is easier? :confused:
    With the digital displays dying, almost necessity...
  7. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    When I was in High school, you'd hook a drill up to the speedometer cable and run it in reverse to reduce mileage...
  8. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The original Gen 2 Prii (I had a 2004) ODO stopped at 299k miles and the ODO had to be replace to track any additional miles.
    JeffD
  9. PriusCamper
    12,048
    4,892
    I see this every once in a while. Is this just for 2004 and before? Or is 2005 and beyond?
  10. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    2004 and maybe 2005. There were updates to the 2006 that may have fixed the 299,999 mile issue.
    JeffD
    PriusCamper likes this.
  11. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    It’s actually not usually illegal to tamper with the odometer; in most countries or
    states etc. what’s illegal is trying to sell it with a misrepresentation of the product (vehicle) by lowering the mileage and increasing its value. So it’s fraud and a bunch of other stuff. Maybe theft by deception if someone pays alot for one with very low miles tampered with. Few things we buy and sell literally say how much they have been used in an actual tangible number that can be compared to others like it. You buy a used TV there is no list that I know of- on some screen that says how many hours or days it’s been used. It’s just weird
  12. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
  13. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I said in most.
    also - if you wanna play with your odometer of your own vehicle and mess with it as long as you don’t try to sell it no one’s going to stop you or care. You just can’t try to sell it. All I meant.
  14. bisco
    51,140
    in ma, you just check 'unknown' on the title for mileage. of course, an intelligent buyer would balk if the seller had represented the car with known mileage.
    Storm88000 likes this.
  15. highmilesgarage
    highmilesgarage Active Member
    435
    158
    Kansas City
    most cars like BMW or Mercedes has tamper proof indicators that the mileage was tampered with or doesn't match with what's in the ECU. BMW will have a dot and Mercedes will not show up the mileage. Typically it's not tampering when you're trying to fix the odometer, I have a Ford Sport Trac that has bad odometer (known failure) causing the fuel pump not to display correctly and the whole thing just shut off randomly. I replaced it with a working odometer which is 14k miles less and as long as you disclose the issue when selling it's okay. I sold it to my friend telling him that the odometer is not correct and you have to add, not sure if he disclosed it to the dealership when trading it so that where's the deception starts. Dealer will just sell it as wholesale and these smaller shops or guys from auction will buy the car without knowing the history and then resold back to the masses.
    For the mustang, can't swap the instrument cluster since it has the security chip in it, so you need to do more work on syncing the keys and immobilizer. For Volvos, the instrument cluster can be swapped without any issues. I have a 245k mile Volvo XC90 with 124k miles on the swapped instrument cluster, no issues with the swap. It was swapped because the lens is cracked and its better to just swap the assembly without messing with the lens and the instrument cluster look clean than the old one. I am still driving the Volvo because of its low mileage..
  16. Mendel Leisk
    40,574
    Odometer roll-back might also be for warranty reasons, and the manufacturers would care about that.
    It's too bad it can't be made bullet-proof, cus there's a host of reasons to do it, none of them commendable.
  17. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Odometer fraud does occur on older Priuses, it's sort of unintentional. People are just swapping instrument clusters to restore basic function, and winding up with inaccurate odos.
    Thing is, that's really only happening on the oldest ones, you (probably) wouldn't want to start there anyway. Writing this in 2022, I would suggest 2015 or newer unless you specifically want a project.
  18. Mendel Leisk
    40,574
    I recall our son had a Maxima with a flakey display, dealership replaced for free, set the miles back to zero, and there was a note in the records as to the miles it was changed at. No way to run a Navy, lol.
