Odometer / speedometer accuracy
Discussion in 'Gen 3 Prius Main Forum' started by Bibster, Aug 14, 2020.
  1. Bibster
    Bibster Junior Member
    28
    România
    Hi folks. I'm questioning the accuracy of either the speedomeder or that of the odometer.
    The reason is that when the speedometer shows 60kmh, for example, Waze shows a speed of 53-54 kmh.
    I wonder if the difference is because I have 15 inch tyres instead of 17.
    I also wonder if that affects the accuracy of the odometer. Thanks! And sorry if the question is ambiguous.
  2. Mendel Leisk
    38,646
    The odometer should be reasonably accurate, there's a lot riding on that, warranty expiration for example.
    Speedometers invariably read higher than actual. How much higher can vary, country by country I think. The intent with that discrepancy is to get people driving a little slower, and ensure you're never being told you're driving slower than actual speed.
    15" vs 17" outside diameter variation is small enough that it gets "lost in the noise". 17" is actually the smaller of the two.
    Bibster likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Some fun with numbers: If a 17-inch wheel registers 60 kph, then a 15-inch wheel will register 53 in the same car.
    Circumference (Pi x D) of the 17 is 53.38 inches, and circumference of the 15 is 47.1 inches. Multiply 60*47.1, then divide by 53.38 to get 53 kph. Tire pressure and remaining tread will also have an effect.
    Bibster likes this.
  4. thuwaragan
    thuwaragan Junior Member
    Boston, MA
    ... except that's not exactly how that works. The 15-inch and 17-inch are the wheel dimensions. The tires go around that. So the actual circumference of the tire is what you need to use, which is wheel + 2x tire sidewall:
    15-inch wheel uses the 195/65R15 tiles. So the total diameter is 15inches + 195mm x 0.65 x (1 inch/25.4mm) x2 = 24.98 inches
    17-inch wheel uses the 215/45R17 tires. So the total diameter is 17inches + 215mm x 0.45 x (1 inch/25.4mm) x2 = 24.62 inches
    So the difference is 1.5%
    #4 thuwaragan, Aug 14, 2020
  5. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    I have 15s, the dash shows 55 mph but obd2 says 53mph on flat road. Radar shows -2 mph also, no wonder other drivers hate prius, they always drive 2 mph slower on roads & highways :ROFLMAO:
  6. Prius Maximus
    Prius Maximus Senior Member
    935
    780
    Northeastern IL
    How would those morons notice that difference when they're going 95+?
  7. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Where I drive it’s 2 lane country side and trucks are they’re not able to do that here. I drive the speed limit at 57 mph to be a true 55 mph.
  8. Prius Maximus
    935
    780
    Northeastern IL
    I drive 10 over and they pass me on the right shoulder, even with 2 or 3 lanes on my left. :eek:
  9. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    Speedometer in miles the US has a very small error. Speedometer in km/h in Europe has about 10% error. Yes, that is true and it is hardwired in the display assembly. Toyota knows the exact speed (that is: the exact number of revolutions the tyre makes) but due to regulations in Europe they choose to add this error.
    There are two rules: the indicated speed should be higher than the actual speed and the indicated speed should be lower than the actual speed times 1.1 plus 4 km/h.
    And lots of car manufacuturers sit around that 10% error. And that irritates the hell out of me because it is not hard to show the exact speed. My 60 year old Peugeot displays the correct speed so why can a new Toyota not do that.
    Attila Fekete and Bibster like this.
  10. Bibster
    28
    România
    Thanks for all the answers. As for the accuracy of the odometer, I understand that it's quite accurate and I will try to check this by comparing the distance that Waze shows, to the distance registered by the odometer. Over a long distance, of course. Don't know if this is a valid test.
