OEM Back Up Camera Successfully Installed
Discussion in 'Gen 2 Prius Audio and Electronics' started by frenchie, Dec 15, 2004.
  1. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    Re: Video input to MFD
    8) :p :p :p
    BINGO.
    I installed a camera TOYOTA (ECLIPSE OEM) 08634-00120 bought from japanparts.com for 27,790JPY.
    This is a very nice (small) device with all the necessary hardware.
    I tried to use the ntsc/rgb converter 08635-28020 but I had no success.
    I did not receive the connector 90980-11922 due date is december 99!!!!
    So I used my home made connector (it works perfectly)....
    I had already a converter from converters.tv the ref is 173.this converter has an automatic switch to cam in reverse.
    they are in australia ,so the shipping cost is something. but the product works fine
    Next I shall shorten the cabling and attach it but it works fine.
    the image is very good and in color.
    I will try to put on line the details.
    It was quite a struggle to route the cable from the cam to the nav_unit , but it is perfect
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Topic Split--I think this deserves it's own thread!! Congratulations.
    Please please do post more photos and details.
    I converted the YEN to USD and got about $270. Not bad at all, but I'm not sure how much the other components cost.
  3. frenchie
    frenchie Member
    150
    48
    attn Evan
    I attach a small pdf with some pictures.
    the cost of converter was 175us$ , shipping around 40us$ taxes in France around 35us$. so alltogether around 250 us$ .
    delivery time 4 days (yes four days only to come from kangarooland).
    this converter ref 173 is not yet on the web site of converters.tv
    it is a new product , it works fine...
    I spent around 5 hours for installing the camera and routing the cable from cam to nav_unit.
    another 2 hours to prepare and test the converter from toyota (no success)
    another 1 hour to prepare and test the cabling of other converter.
  4. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    Only one word for it...INGENIOUS.
  5. brosnan
    brosnan Member
    159
    Silicon Valley
    Excellent work! Could you send a photo of the #173 converter? Any modifications needed inside it?
  6. Tideland Prius
    16,124
    Congrats! I have a question though. In the last picture of your attachment, it looks as if the camera image is reversed. Other than that. WOW
  7. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    frenchie,
    I looked at the PDF. That camera is so small I didn't even see it in your original picture! I was wondering why you posted a picture of your license plate. :) I can see it, now I know what I am looking for.
    That would make parallel parking, in any vehicle, so much easier! All we need now it a kit or at least a parts list of everything needed as the whole process has been a try this, then that, then the other thing. Maybe an item for the knowledge base. Part numbers, source and instructions.
  8. disneydad
    disneydad Junior Member
    85
    Leominster, MA
    Great job, Thanks for sending the pictures.
  9. frenchie
    frenchie Member
    150
    48
    to Brosnan
    attached picture of converter 173.
    you can have an idea of the size compared to a miniDV cassette.
    could you please give me the detailed connexions you used for your converter ; mine does not generate 9v for the cam...
    once working, I will check the bypass/switch of this converter, when you check the white connector on the left , you will find TX+, TX-, ground, ground, and 4 pins with 75ohms impedance so definitely it should be standard video input for RGBS.
    regarding mods on the173 converter, I just put the internal jumper for sync on 1-2 (sync type positive). for the cam I will use a voltage regulator 7809 because I am not sure if the cam can accept 14volts. my tests were done with a 9v battery , I am on the conservative side regarding electronics.
    next week-end I will try to feed a PAL video from a camcorder to see if the MFD can synchronize to 625 lines 50hz interlaced.
    I will also check if there is a possibilty to mirror the image inside the cam.
  10. frenchie
    frenchie Member
    150
    48
    forgot the picture!!!
  11. frenchie
    frenchie Member
    150
    48
    some more pictures about connexions
  12. frenchie
    frenchie Member
    150
    48
    result of pal video from camcorder on european prius.
    the image is stable but not at the right heigth.
  13. john_molendijk
    john_molendijk New Member
    This is great! A real breakthrough!
    Some queries I still have:
    Do you have any photo's showing where and how to reach the prius video interface (plug)? What is the connector pinning?
    Does the prius display require RGB only or can it deal with composite video?
    Thanks,
    John.
  14. brosnan
    brosnan Member
    159
    Silicon Valley
    Frenchie,
    Thanks for the photos - I've definitely got to upgrade to color. Great job on the homemade connector. As far as more detailed instructions for my setup, have you seen page 3 of the zip file referred to at http://www.priuschat.com/forums/-vp45751.html#45751 ? Let me know if there's a certain area where you want more detail or photos.
    John,
    The connector we've been using is under the seat on the back of the nav ECU. You unplug the small white connector. The cable that's now loose goes up to the MFD. Pinout is as shown in the zip file just mentioned. IThe MFD can only deal with RGB+Sync in a format similar to what normally comes from the nav ECU. But if you get a converter from composite video to RGBSync and build a custom connector harness like in Frenchie's photos, other sources can drive the display. Sounds like this #173 beastie does away with switch boxes and automatically switches to backup camera in reverse (and passes nav ECU images through otherwise).
  15. frenchie
    frenchie Member
    150
    48
    to john
    start with this thread, Brosnan did a wonderful documentation. somewhere you can download a pdf from him.
    http://priuschat.com/forums/video-input-to...mfd-vt2281.html
  16. frenchie
    frenchie Member
    150
    48
    to mike
    maybe my converter 08635-28020 is defective?
    I did like your indications ,only doubt is regarding pin marked 1G on the grey connector; I connected nothing on it. maybe I should put it to ground to..
    to everybody:
    Another very good point : the camera is working the right way, that means like the rear mirror : left is on the left & so on.
    I will try to take good pictures of cam in action.
    I confirm that activation of the cam & the switch to cam is really automatic when
    1)you are in mode MAP or DEST
    2) you engage reverse.
  17. Tideland Prius
    16,124
    This is only available to those with a navigation system?
  18. brosnan
    brosnan Member
    159
    Silicon Valley
  19. brosnan
    brosnan Member
    159
    Silicon Valley
  20. Ken Cooper
    Ken Cooper New Member
    339
    An alternative to the backup camera is the talking ultrasonic backup sensor. I bought one after twice backing into objects that I didn't see. Only two times I've done that in 50 years of driving. Something about this car ...
    Anyhow, I bought it, installed it (easy install), and now have a female voice that tells me how many feet an object is behind me when my reverse light is on (also, at closer ranges, an alarm sounds that gets progressively more alarming with closeness). It works VERY well. I'll never back into an object again. I bought two, one for my not-so-careful sister, and one for me ($145 for one .. $258 for two).
    Here's a link to the Autotoys site I purchased it from:
    http://www.autotoys.com/x/cust/product.php...=5&cat=0&page=1
