OEM double din fascia for aftermarket NAV
Discussion in 'Gen 3 Prius Audio and Electronics' started by Ananda, Jun 29, 2010.
  1. Ananda
    Ananda Junior Member
    tacoma, wa
    Is there a double din fascia available that matches the existing Toyota trim texture and color?
    I'm doing research for parts for a NAV install on my new Prius II. It seems like this part is the main compromise. So far it seems the parts available are:
    1) A product(s) from Schosche - but doesn't match color and/or texture of existing trim
    2) A product(s) from Metra - but doesn't match color and/or texture of existing trim
    3) Toyota OEM trim piece from UK, matches "UK din" which is reported to be a different size?
    I'm in the US. I'm considering installing the JVC KW-NT3HDT. I plan to contact the dealer but thought I'd check here too. Thanks in advance - loving my new Prius!
  2. Jeremy Harris
    Jeremy Harris New Member
    221
    39
    Salisbury UK
    I have the official (and expensive) Toyota trim panel, but it's intended for Toyota's own aftermarket nav unit, the TNS510, so is 20mm wider than a standard double DIN opening. However, it is a perfect match for the rest of the fascia, unlike the other fascia panels on offer.
    If you want to use a standard double DIN head unit with this Toyota panel, then you can use the Metra infill kit. This is two small pieces that fit either side of the Toyota fascia and convert the hole to a true double DIN width. Because these pieces are small, they don't look as out of place as the whole fascia being the wrong texture.
    Jeremy
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    The downside to using the Toyota part is cost - you're looking at around $100 all in.
    The Metra and Scosche are cheap (less than $20), and generally available. They don't look perfect - but aren't bad either...
  4. Ananda
    tacoma, wa
    Thanks!
    Anyone know where I can order these Metra infill pieces? Or do I need to order the whole kit for just two small pieces?
  5. Jeremy Harris
    221
    39
    Salisbury UK
  6. rrolff
    1,610
    246
    So Cal
  7. Ananda
    tacoma, wa
    Thanks guys!
    To sum it up, the Toyota trim part numbers are:
    55405-47080 - for main trim for 2010 Prius
    86221-52050 - for side 10mm filler (left?)
    86221-52060 - for side 10mm filler (right?)
    I ordered all three from discount toyota parts dot com (google it) for $92 shipped.
    The main trim costs $59 w/out shipping from the source I cited, which is less than the eBay source.
  8. rrolff
    1,610
    246
    So Cal
    Please take pics - $59 plus shipping is really good - and closer to a real world price!
  9. Ananda
    tacoma, wa
    Photos are attached.
    It took 2 weeks from day of order to delivery. After a few days they called to tell me the part number(s) didn't match the 2010 Prius. After assuring myself and him that I knew what I was doing, he ordered the part (it was not in stock).
  10. Jeremy Harris
    221
    39
    Salisbury UK
    Looks good, those Toyota infill pieces are much nicer than the Metra ones I have and make for a neat looking fit.
    How do you like the JVC? I'm torn between the EU version of the JVC unit you have and the Clarion NX700E (the EU version of the NX700). They both run the same nav software as far as I can tell, OEM versions of iGO, which is probably the best there is, in my view. I like the idea of a volume knob, rather than push buttons, so am leaning towards the JVC KW-NT3 at the moment. Any feedback you can give would be most welcome.
    I had a look at an Alpine iXA-W407BT a couple of days ago - a nice unit, with a great interface, but spoilt by a nasty low resolution and very grainy looking screen.
    Jeremy
  11. Ananda
    tacoma, wa
    Overall, the JVC is really nice. I've never owned anything similar so my reference for comparison is light. I love the SD card slot - by far my favorite single feature. I use a 16GB SD card which holds lots of music. I like the display and the use is very intuitive. The EQ feature helps quite a bit. The FM (or HD) reception is not impressive - likely due to the inadequacies inherent in the 2010 Prius that you have written about. The bluetooth is OK - the integration of the phone with music/NAV is awesome but the quality for the person on the recieving end of the conversation is worse than my in ear Jawbone Thinker. I like the highway/traffic information provided, it is pretty accurate. The NAV is adequate. I like my $100 Tom Tom better, but perhaps I just need to get used to and more familiar with the JVC NAV.
    One thing to know, that is not advertised anywhere is that the JVC limits what features work while the car is moving e.g. you cannot enter an address to navigate to while the car is moving. However, if you ground the parking brake line from the HU then every feature works whether car is moving or not.
    The SWI-JACK has a one second delay (seems like maybe even more but I haven't timed it), but all the steering while inputs work fine to control the JVC. I find that due to the delay, I end up touching the HU more than the steering wheel controls.
    I'm glad I did not buy the Toyota JBL sound and/or Toyota NAV ($2k or $3k?!). This JVC has far more features, sounds better and has a better NAV i.e. you can use it while driving. The sound quality of the JVC is pretty good with my stock speakers but I do plan to upgrade those too sometime in the future.
  12. Jeremy Harris
    221
    39
    Salisbury UK
    Very many thanks for taking the time to give this feedback, it's very useful. I'm pretty sure that I'll go for the JVC, if I can get one at a decent price.
    I'm still investigating the possibility of fitting a better amplified aerial, one with some decent band pass filtering to reduce the level of out-of-band interference getting to the receiver.
    Jeremy
  13. skylarii
    skylarii New Member
    34
    OR
    With the Toyota trim you used and I assume you used the original mounting brackets, did you have any problems with the mounting depth? How did you adjust for the difference if any?
    Thank you
  14. Rebound
    Rebound Senior Member
    3,972
    2,627
    Portland, OR
    How do the side infill pieces fit? Are they tight? No wobbling?
  15. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    After market brackets can be used, but mine uses factory with a few holes stretched. My Kenwood came with a filler "piece" that was cut to fit and mounted to the back of the Toyota faceplate. Same color.
  16. skylarii
    skylarii New Member
    34
    OR
    I went ahead today and answered my own question via a trial fit/ installation of the avh-p3200bt by using the idea by Spiderman to grind off the little nubs on the stock brackets that came off the Toyota basic radio. I was able to find matching holes that lined up to the brackets that moved the radio up about 1/2 cm. This was all that was needed to make for a very tight but good fit using the matching Toyota filler brackets. I did have to grind off the ridges and also cut away some of the material so it could fit against the rim of the stock metal brackets. It was very minor given I used a Dremel cutting and grinding wheel. I also had to cut out a divot of material from that plastic filler so it could fit around a mounting screw for the metal bracket. Given these things, it all fit well and the only complaint was a gap on the bottom of the HU against the Toyota bezel. Can be easily filled in and I have some ideas to address that. Forgot to mention that you need to do the prep work on the black plastic Toyota filler pieces so it has a nice tight fit against the HU. I am referring to the info from Spiderman to grind down the high ridges you find on those plastic pieces.
    So all in all, a successful fitiment process today.
  17. rsg
    rsg Member
    64
    Harrisburg, NC
    Can you post some pics?
  18. MrPete
    MrPete Active Member
    477
    187
    Colorado, USA
    I've taken pix of my process... including how to measure and adjust. Hope to find time soon to upload to the Prius Wiki.
    I went the "real Toyota" route for the surround and am VERY glad I did. Yes, costly. But it matches the rest of the dash perfectly. The Scosche plastic is plain/smooth material and obviously different. Looks like a hack job; I would not want to buy a car looking like that if I could avoid it easily.
  19. alfa737
    alfa737 Member
    126
    27
    u r right. i just put the metra surround. it fit nicely but has no texture, it is smooth.
    wish i would have gotten the oem stuff from toyota.:(
  20. Rebound
    3,972
    2,627
    Portland, OR
    I bought the Metra and the Toyota. My Toyota dealer special ordered the fascia part and I think they charged me only $57. They fit differently. With the Metra, you assemble both the side pieces to the front fascia, then you attach them to the head unit. Do this, adjusting the side pieces to the head unit so that its front fits flush against the fascia piece. Then remove the fascia piece, keeping the side pieces on. You then bolt the head unit into the car, and when you put the Toyota fascia piece over it, the head unit will fit flush with the fascia.
    Test fit the in the dash BEFORE connecting the wires. It's a painful trial-and-error process if you connect and disconnect all the cables each time, just to micro-adjust the side brackets for a perfect fit. The good news is that there is a lot of space in the dash for your head unit, so it's easy to adjust tilt and front-back fit. When you're final, be sure to wrap loose cables to prevent rattles down the road.
