OEM hybrid battery swap - how to swap electronics
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by underoathfan87, Apr 9, 2026.
  1. underoathfan87
    underoathfan87 New Member
    Los Angeles
    Got an OEM hybrid battery from the dealership to swap in for my old dying one on my 06 standard prius..thought it'd be plug and play but now it looks like i need to transfer the electronics over (ECU, relays, wiring harness etc) from the old one to the new one.
    Can't for the life of me find a good tutorial on youtube or elsewhere showing how it's done. I took the safety plug out but i know there's still a lot of current in the buses and opening up the battery to move the wiring harness over is sketching me out a bit without a good guide.
    Can anyone point me to a good resource on this or have other advice? The mechanical part of it's no problem, I just wanna make sure i know what is and isn't live before i start digging around in the battery..looked around the forums here but haven't found anything.
  2. saneesh8
    saneesh8 Member
    223
    Allen, TX
    ChrisFix have a good one in YouTube.. Did you check that? He was changing the cells, but the electronics parts should be visible?
    How many miles on the original one?
    Here in Dallas area, there is a company comes to home and replace it with OEM battery for $2200 and they give 5 year warranty also.
  3. underoathfan87
    Los Angeles
    yeah that one was helpful, but he doesn't do anything with the electronics..i was hoping to see someone move those over.
    207k mi on original battery.
  4. PriusCamper
    PriusCamper Senior Member
    13,231
    5,352
    Pacific Northwest, USA
    Wiring harness and bus bars come already installed on a new OEM pack... You just unbolt the relays and sensors and ecu from the old pack chassis and botl it to new pack chasis and plug everything in. Usually takes me 2.25 hours from start to finish.
    As for holding voltage after orange safety plug is out, it's wise to be cautious when you're new to it, but once that circuit is broken by removing orange plug its safe to handle. To confirm, measure this voltage with a multi tester on the battery side of the relays.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,937
    888
    Southern California
    There were a couple of long wires that were included and had to be installed, trying to remember... I think it was the ones that go to the safety latch. Had to buy a very low value torque wrench to put those couple of nuts on.
    I suggest the OP take careful pictures of the electronics area from every possible angle for reference. Also of the top of the pack, as the rubber tube thing needs to be moved as well. Then take careful notes on how the wires are routed into and through the electronics area. It wasn't that complicated, just move everything from one pack to the other and put it all back together the way it was in the first. But having noted where all the wires go first is important.
    I would also suggest getting a set of JIS bits ahead of time and use them to open the ECU and inspect the inside for corrosion, which will be at the wiring connectors. I didn't have any JIS bits at the time and the Philips head bits and screwdrivers did not fit right, so I gave up rather than risk stripping the screw heads.
  6. xw20_driver
    xw20_driver Member
    116
    58
    PNW
    Not a detailed walkthrough but this video after 17:22 you can watch the process of removing the components off the old pack over to the new pack.
    Be sure to take the rubber tubes and the black plastic vent block that clips on top near the ECU side. That block is to prevent the cooling air from going past the 1st block to force the air between the blades.
