OEM parts win
Discussion in 'Fred's House of Pancakes' started by galaxee, Apr 4, 2009.
  1. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    DH was driving his 1990 lexus the other day when the taillight-out warning came on. so he bought a pair of replacements and decided to replace them both. the one that had burned out was an aftermarket replacement bulb. the one that still worked was the original equipment bulb, nearly 20 years old.
    not bad, eh?
    we're seeing the same thing with the aftermarket headlamps we've put in the prius. they last us a few months. meanwhile, the OEMs lasted about 4 years under the same conditions.
    we think we're going to pay a couple bucks extra for the OEM parts next time.
    2 people like this.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    That's actually GOOD advice!
    Brings to mind the old saying...
    "Ya Getz Whatz yaz Payz For!!!
  3. dogfriend
    7,512
    1,187
    Carmichael, CA
    Having the most experience with Toyotas and Fords, I would say this is definitely true for Toyota; the quality of OEM parts is very good and its not worth it to go for aftermarket.
    With Fords it is hit and miss - some OEM parts are good, but you can sometimes find aftermarket that are just as good (or even better) for less money. I have had good luck with Napa parts for the Fords. Don't buy super cheap parts (Pep Boys / Kragen / Checker) for any car - you will spend more time in labor and frustration than you will save on the part price.
    I often see those ads for Pep Boys that feature brake pads for cheap prices - Is that really the kind of part that you should try to save a few bucks on? Doh!
  4. Patrick Wong
    18,200
    6,479
    In the 80's and 90's I owned three "luxury" European vehicles: a 1985 Jaguar XJ-6 VDP, a 1988 BMW 325i convertible, and a 1992 Mercedes 400-E sedan. Parts were quite expensive when purchased through the local dealers' parts depts. I found that aftermarket parts produced by the original equipment supplier were of acceptable fit and quality; and priced considerably lower compared to the same parts that had the vehicle manufacturer's logo.
    I agree that aftermarket parts made by dubious sources are to be avoided.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    While I agree with the OP, the non genuine part is only there because the genuine part already failed.
  6. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    When dealing with bulbs of any kind, it's hit or miss... When you get a bulb at the store and it has an advertised lifetime on it, that amount of time is the average over tests ran on thousands of bulbs. The bulb could burn out tomorrow, or it could last double the advertised lifetime. In the end, it all works out on averages.
  7. daniel
    14,487
    1,518
    Spokane, WA
    I always insist on OEM parts. As Tom & Ray say, "It's the stingy man who pays the most."
  8. Tideland Prius
    16,160
    It depends but generally, yes I agree. $50 for a cabin air filter isn't one of them (when $20 gets a much better filter)
  9. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Regarding the cheapest place to get OEM parts: I've noticed that my local mechanic/body shop guy charges me less for genuine Volvo OEM parts than either my Volvo dealer or the cheapest of the online vendors of Volvo OEM parts.
  10. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I just helped a friend replace a taillight in her 2003 GMC Envoy. I was surprised to find it was a Sylvania bulb, just a different part # than the long life one on the shelf.
  11. Boo
    5,051
    485
    97
    Flushing, NY
    Re: OEM versus Aftermarket Timing Belt
    I apologize if this is a hijacking of this thread, but ...
    1. Does anyone have an opinion about OEM versus aftermarket timing belts?
    The particular car in question is a 2001 Mitsubishi Galant, and the choice is between the Mitsubishi OEM versus the Autozone aftermarket timing belt.
    I'm inclined to go with the OEM timing belt which I think may be twice the price of the Autozone aftermarket belt.
    2. Also, is it standard or recommended that when one changes the timing belt one should also change the balancing belt?
  12. galaxee
    9,810
    465
    MD
    Boo-
    1. buy OEM t belts, definitely.
    2. you probably should. [grumbling about mitsubishi]
  13. Boo
    5,051
    485
    97
    Flushing, NY
    Thanks. I value your opinion a lot.
  14. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    It's not exactly current, but I used to own a Corvair (actually 2). It took exactly one purchase of a non-OEM fan belt to convince me to go OEM. The belt traversed 4 pulleys, and also did 4 90-degree twists along the way. The aftermarket belt that I tried lasted about several hundred miles. OEM was probably good for 20,000 miles. Prudent owners carried a spare, and the tools to change it.
    It's sad that GM got so burned by how different the Corvair was. The design was similar to the then current VW Beetle, but larger. GM tried to be innovative, got burned, and developed a crippling fear of anything "different".
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,998
    Fort Lee, NJ
    OEM bulb may last a very long time but it gets dimmer. In my previous car (00 Celica), I changed them because they got dimmer after 5 years.
  16. Patrick Wong
    18,200
    6,479
    Maybe this isn't available in Canada, but in the US you can purchase the correct cabin air filter for ~US$15 plus shipping from several Toyota dealers that sell via the internet.
  17. galaxee
    9,810
    465
    MD
    yeah, parts markup sucks. we're kinda immune atm.
  18. Tideland Prius
    16,160
    Looks like I should head down south once again??? lol.
  19. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Hey, if you're going, I'd be happy to pay you back for some filters. :)
  20. Tideland Prius
    16,160
    I would but I just returned to you know where so maybe in the summer when I take time off. The other option is to order from MicronAir directly.
    Patrick, do you know if it's only via online shopping to get the special price?
