OEM rotors and pads mediocre
Discussion in 'Gen 4 Prius Main Forum' started by shadow4478, Nov 27, 2021.
  1. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    I have about 100000km on my 2017 Prius
    Not sure if it’s because I live in Canada Ontario and the salt destroys the brakes.
    i replaced the front pads and rotors at 70000km and rears at around 100k
    Both times down to metal.
    I did regular brake service and the brakes wore fairly even within 5% comparing from passenger vs front driver and same for rear.
    I replaced the front with Toyota OEM dealer parts and rear with aftermarket Napa premium parts. I used to be the biggest fan on how Toyota brakes last and wear on my previous Tacoma, the Prius being a vehicle that conserves braking with pads is subpar what I expected. They do great during summer but get destroyed in the winter. The Napa rears seem to be overall treated better you are way less rust blooming and flaking.
    Not thrilled with Prius OEM dealer brakes
    52,368
    there have been odd reports of all generations with brake problems due to salt. maybe it is strictly personal use conditions, or some are just defective.
    on the whole, most have no issue
  3. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    I feel it’s the area salt, and how the metal reacts. High humidity with weather -30 to +30
    Parked outside, I’m ok with changing the brakes out after 70k km, but hoped for more.
  4. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
    I have replaced the rotors on four of our vehicles so far with zinc plated ones ( PowerStop brand ).
    They have been holding up far better than the OEM rotors did...and we are in a high road salt area. Full disclosure that I did this as an 'experiment' on the first vehicle ( 2012 Prius v wagon ). I liked the result so much that I have been swapping the rotors out on the other vehicles when the time comes. For me it's a 'why not' type of thing at this point since I'm in there doing a brake job anyway.
    Jburner likes this.
  5. Mendel Leisk
    41,879
    I've got around 93K kms, and when putting the snows on I see the front pads are around 6mm still. Maybe punishing amounts of road salt in your area are corroding the rotors, accelerating wear?
    Rear pads I had to replace early, and they're currently maybe 8mm. I messed up rear caliper piston orientation first time round.
    Rotors all fine.
    Mandrade007 likes this.
  6. esfishdoc
    esfishdoc Junior Member
    26
    45
    ESVA
    My brakes are still fine at 140K on my 2017. I guestimate my miles are about 60-70% highway. There is a saying that salt is harsh on everything but saltwater and saltwater fish.
  7. orangecones
    orangecones Member
    46
    28
    NZ
    My parents have a 2014 with at least 80k miles at last check in Chicago, which should have fairly similar road surface salinity to where OP is, and I am fairly certain it's still on the factory brakes. I haven't exactly taken the wheels off and looked at them in person, so not sure what state they are in, other than being functional and the mechanic not telling my dad it's time for new brakes yet.
    Although, I'm also not surprised that Toyota maybe used inferior brake components on the Prius as a cost cutting measure. It's not a performance car by any means so quick stops aren't super important (except you know - for safety). Also because in most normal conditions MG2 is doing a good deal of the work, from a durability perspective, even crappier pads and rotors will still (typically) outlive nicer ones on a conventional vehicle.
    pilotgrrl likes this.
  8. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Yep, salt is our Kryptonite! I hate it! I'm originally from Maine and "rust bucket" is what a car becomes in too short a time period!
    Do you have any car washes that run in the winter? We have one that has the under-carriage spray and I'll run my cars through it during the winter (when it warms up over freezing) after we've had snowstorms and that seems to help keep the rust down. (They do use salt in Colorado but also add corrosion inhibitors so I don't think we get rust as bad as Maine used to....not sure if Maine is better now or not.)
    Anyway, I do all my families brakes and have favorites....Bosch rotors and Import Direct pads (ceramic for cars, semi-metallic for vans and trucks) IMHO I don't think they are much different than the OEMs Toyota uses.
  9. Mandrade007
    Mandrade007 Junior Member
    Mexico
    Two Eco
    do you have and can you share instructions for replacing brakepads?
    I'm so thankful with you, all the information that you share is so helpful.
  10. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    I don’t you can find instructions here on forum or search the web and YouTube.
    i did. go with aftermarket premium raybestos brakes and overall much better !
  11. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have found that the OE pads are fine. The OE rotors do tend to rust (as we all have discovered) and a rusty rotor will cause the pads to wear as well as make noise when braking. I make it a point to periodically clean the rotor surfaces:
    1. Get up to 25-30 MPH with no traffic
    2. Put your Prius in neutral so that regenerative braking is disabled.
    3. Lightly step on the brakes
    4. Repeat as required until the braking smooths out and the noise is diminished.
    As our farmer friend noted in an earlier comment, zinc plated rotors resist rust so as to look better, but not on the braking surface as the zinc plating on the braking surface quickly wears away.
    JeffD
  12. Mendel Leisk
    41,879
    Repair Manual info attached.
  13. ChapmanF
    18,521
    That's generally the way I do it, too. If I notice that grinding noise as I'm pulling out of the driveway, I'll shift to neutral for the first stop signs out of the neighborhood, and that usually takes care of it. It's pretty much second nature to me now, I'll do it almost without thinking about it, when I hear that noise.
    You'll see other members who don't do anything special, and just wait for their normal driving to scrape the rust down. Just takes a little longer that way.
    Probably neither way is significantly better than the other; I think I do it my way because I hate my car sounding like a hooptie, so I correct the sound right away.
    Either way, scraping the rust off the rotor naturally wears down the pad too. It's probably about the same amount of meat off the pad, whether you follow "shift to neutral and fix right away" or "wait for normal driving to do it".
    The one thing I'd say is don't let the rotors stay rusty; if you normally follow "wait for normal driving to do it" but you still hear noise at the end your normal drive, do some neutral stops to make sure it's cleaned up. Leaving the rotors rusty gives the rust a chance to get deeper, and harder, and more abrasive to the pads.
  14. Mendel Leisk
    41,879
    If I’ve washed the car and it’s then sat a few days, next drive will have noisy brakes, for the first mile or two. Even without shift to neutral tactic: pretty much every time I touch the brakes.
  15. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just a friendly warning, the OE rotors do build up significant rust on the outer edge. When I brought my 2004 Prius in for it's 60k mile maintenance, the technician said that I needed a full brake job. I declined and at 12 years and 288k miles the original pads, rotors, drums and shoes were all still on the car and no problem stopping the car.
    JeffD
  16. ChapmanF
    18,521
    Another thing is that, if not used often enough, the rust that starts at the rotor edges just works its way inward. Eventually you have only a stripe in the middle where braking happens.
    The rust at the edges gets well-enough established that the pads can't wipe it off anymore. Instead, it adjusts the shape of the pads to suit itself.
    Note in the upper photo that you can see the pad is being eaten from both the top and bottom edges.
    The bottom-edge contour isn't visible in the lower photo because its radius doesn't reach out to the side edges yet.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Yep that crap on the roads in the winter can do a lot of damage to even quality parts. Here in Colorado, during the winter, whenever we get a warmer day (above freezing), I'll wash my cars and spend extra time spraying down all inside the wheel wells and also the tires and brake areas to wash that stuff off...seems to help a bit in our vehicles.
    My wife's 2017 Prius only has 27,000 miles and I checked her front pads during the last tire rotation and, still, has 6mm....so looking good.
  18. Jburner
    Jburner Member
    68
    44
    Wisconsin
    This very thing just happened to my 2016. It's the rotors that kill the pads. It's the salt that kills the rotors. And make doubly sure you check the inner pads (esp in front) as they are the ones that get the use if the slides freeze up. Get coated rotors if possible, and keep the salt off. No easy fix for that. Ceramic lube the slides every 30-60K if used in salted areas. Thankfully, my pistons weren't seized, but the slides were certainly dry and "stuck" enough not to do their job.
    Tip: The rear pistons need a special tool to turn the piston in and I had to use silicone spray to avoid the rubber boot being torn as the piston turned. Too much corrosion equals sticking rubber parts. I will be coating the underside of my Prius for winter with Fluid Film to save the frame and hardware.
  19. ChapmanF
    18,521
    I do a quick inspection with every tire rotation. It includes wiggling the calipers in and out on their slides. Done frequently enough, as with tire rotations, that's easy to do. You will feel that the existing slide grease got a little peanut-buttery, but it wakes right back up with just a few strokes in and out. (Keep in mind that in their normal life, they aren't moving more than a third of a mm in either direction.)
    Just keeping up with that, I hardly ever have any need to further disassemble or regrease anything. (On the rare occasion when that's needed, it's worth knowing that Toyota does not specify any silicone grease for that use. their spec is a glycol grease with lithium soap thickener. 08887-01206 to buy a whole tube, but you don't have to if you buy a caliper rebuild rubber kit; it comes with a little packet of the right grease.)
    Don't overlook other parts besides the slide pins. The fitting kit (springy clips that insert in the caliper mount and hold the pad ears) can need attention too. Those don't take grease (it would only hold dust and grit), but they come with a dry Teflon-like coating when new, and it can wear off, and later they can rust, and that also keeps the pads from releasing. A new fitting kit is quite inexpensive.
