OEM smart key system installed on Prius C One.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Don Kaufmann, Sep 1, 2012.
  1. Don Kaufmann
    Don Kaufmann Junior Member
    Clarksville, Tennessee
    I
    I was just wondering if even possible, if anyone has installed OEM parts for the smart key system in a lower model Prius to achieve the same result as the higher model???? While i'm at it, OEM cruise control too.
  2. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Are we talking about the SKS system? It comes standard on the base Prius v.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I moved this to the proper Prius c forum. The OP owns a c but posted, probably accidentally as many others, in the Prius v forum.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Unless the door handles are interchangeable between the c and regular Prius hatchback, then I would say no dice. The door handles have the necessary sensor and antenna for the SKS system so you would have to replace your non-SKS door handle with SKS door handles and that's even before considering whether the c has the necessary electronic module to accept the SKS system in the first place.
  5. kdkuhns3
    kdkuhns3 Member
    38
    26
    Norwood, MA
    I believe the OP is looking to find out if the SKS and push button start that comes on the Prius C 3 & 4 can be retrofitted to the Prius C 1 & 2 which has a standard keyless entry remote and a key cylinder to turn the car on.
