OEM Wide Angle Side Mirror
Discussion in 'Gen 5 Prius Accessories and Modifications' started by SilverFilament, Apr 6, 2026 at 2:40 PM.
  1. SilverFilament
    SilverFilament New Member
    Today
    2026 Prius
    I had aftermarket wide angle side mirrors on my previous car and really missed them on the Prius. I had GR Corolla owners import JDM mirrors since their left hand mirror (US car driver's side) is wide angle, and wanted to do the same for my Prius.
    After a lot of research and placing an order from Amayama, I can confirm that Toyota Part number 87961-47750 is the correct part for the JDM left side mirror with the BSM (blind spot monitoring) light and internal heater. The mirror works perfectly and has a great, wide angle.
    Easy installation, just gently pry the mirror to pop it out, and disconnect 2 connectors. Just be aware that a convex driver's side mirror may not be legal in the US. The mirror also does not have the "objects in mirror are closer than they appear" text, so you may want to remind others if they drive your car.
