Offered $1000 Goodwill warranty towards replacing HV Battery..new or remanufactured?
Discussion in 'Gen 3 Prius Technical Discussion' started by CluelessPriusOwner, May 23, 2017.
  1. CluelessPriusOwner
    CluelessPriusOwner New Member
    San Mateo
    I am trying to make a decision as I have received the dreaded Code P0A80. I took my 2010 Gen 3 (w/226K miles on her) to the dealer, and they explained that my HV battery had over heated because the port for the fan to cool the HV battery was clogged (This is located in the rear passenger side in between the door and seat). I was not aware that this has to be cleaned (the dealership recommended every 5k miles). So based on this explanationI took the time to disassemble my back seat to access the fan and port to ensure they are clean and good as new.
    After I cleaned the port and fan, I disconnected the 12V battery to have the system reset. This removed the "Check Hybrid System" warning and allowed my car to operate on both battery and motor again. My thought process was that perhaps the warning would come on, force motor only, in an attempt to preserve the battery from being damaged from overheating. If that was the case, and my port and fan were now operating as intended, I would not expect the "Check Hybrid System" warning to come back on. Several days later it did, so this meant I was going to escalate to the next plan. I contacted Toyota, requested the help through their goodwill warranty. They responded with a willingness to offer $1K towards the replacement.
    I was informed by the dealership the replacement would cost $3200 less the $1000 offered from Toyota, roughly costing me $2200 plus tax. I am weighing this against options from GoVoltage and GreenTecAuto both with remanufactured batteries with a 1 yr and 18 month warranty respectively. Both are roughly $1850.
    The decision is that I can save the money by waiting another week more for the Dealer option, but it hurts my heart a little bit to have that amount spent..so just looking for thoughts.
    Thank you in advance.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    For the small difference in price, I would opt for the Toyota option.
  3. CluelessPriusOwner
    San Mateo
    I am awaiting confirmation from the Dealership to make sure that I understood them properly, because I am not certain that the $3200 quote includes the $1000 credit or not. So if the choices are $3200 or $1850, let me propose that question.
    1. Should I save up for the $350 difference for the new battery (dealership offers 20K/1yr warranty, 3rd parties unlimited/1yr or 18month warranty)?
    2. I the difference is $1350, is it worth saving up for the new battery?
  4. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    When my hybrid system went bad, I ended up replacing the one bad cell for 30$ You will have to rebalance charge all the batteries and make sure they are within 8.1vdc. This is dangerous if you do not know what you are doing. Toyota is lazy and does not troubleshoot anything. They want to replace the entire system. I was quoted 3500$ and 1000$ back for the core(old battery), and will give you a warranty. 30$ for a charger. 30$ for a battery and 30$ for a meter is better than 2200-2500$ and if it happens again, you can fix it. Make sure to disconnect orange plug while servicing battery. good luck.
    link to testing/charging
  5. bisco
    51,968
    i would go for the toyota. all remanufactured batteries are iffy at best, and only as good as the parts and labor warranty.
    that's a pretty sweet deal from toyota. at 226,000 miles, neither they, nor the car owe you anything.
  6. K-Dub
    K-Dub Junior Member
    30
    Phoenix
    What does that whole battery assembly weigh??
    Never mind. It weighs 93lbs according to Google.
  7. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Yes but this is really not a DYI job. Not only you need a safe place to do this. It also require familiarity and some expertise working with electrical components. Not for the faint hearted. Doable yes can most prius owner do not by the longshot ....
  8. Mendel Leisk
    41,485
    Especially since there are some components that need to be transferred, and to keep the warrant quibble free, I would let the dealership handle the whole thing.
    $2200, if that turns out to be accurate, is a good price. (y)
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    If they are putting in a "new" battery, go for it. New beats refurbished or reconditioned when it comes to our batteries.
    m.wynn, Raytheeagle and Mendel Leisk like this.
  10. Mendel Leisk
    41,485
    The joker in the deck: some dealerships are starting to offer Toyota refurb's??
  11. bisco
    51,968
    iirc, the toyota refurb is as good as new. i would be willing to take a chance for a reasonable incentive.
  12. bisco
    51,968
    any news? it's been 2 weeks, you should have saved up $350. by now. :cool:
  13. rogers32
    rogers32 Junior Member
    PA
    Ask anyone that's had a refurb, get the new one. I'm on my third failure in two years with a dorman, still under warranty yes, but the two to three weeks it takes to get the replacement for the second and now third(10 days and no resolution yet) I'm not sure the hassel is worth it. Plus dorman tried to blame it on the car, $105.95 for a diagnostic report from Toyota giving the car a clean bill of health and pin pointing the problem to the battery has been provided at my expense too. No one is giving me any real solutions yet, sure offer a refund of the battery price, but then they want the core and leave me with no core to trade in. Get the new one, even a rebuild from Toyota is all new cells they told me.
