Official 2023 Toyota Prius Pricing, Packages, & Options
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    LE AWD
    XLE AWD
    MSRP*
    $27,450
    $28,850
    $30,895
    $32,295
    $34,465
    Limited AWD
    $35,865
    Digital Key Capability** ($275)
    Digital Rearview Mirror ($200)
    Front and Rear Parking Assist with Automatic Braking ($35)
    12.3-inch Toyota Audio Multimedia Display ($735)
    Fixed Glass Roof ($1,000)
    Optional Features/MSRP
    Heated Rear Seats ($350)
    Packages/MSRP
    Limited Premium Package, includes Advanced Park and Panoramic View Monitor ($1,085)
    Available Paint MSRP
    Colors/Premium Cutting Edge, Guardian Gray, Midnight Black Metallic, Reservoir Blue Premium Paint: Wind Chill Pearl, Supersonic Red ($425)
    *MSRP excludes Dealer Processing and Handling of $1,095; Prices subject to change
    **Remote Connect Subscription Required
    #1 Danny, Dec 14, 2022
  2. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    @Danny Do you know when they will announce the specs and prices on Gen5 Prius Prime plug-ins?
  3. Mendel Leisk
    40,918
    Any mention of a spare?
  4. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Interesting that it specifically mentions 3 door SKS and push button start for XLE and above but nothing about what the LE gets for key or even drivers door SKS... Physical key?
  5. Trollbait
    12,417
    Tideland Prius and Mendel Leisk like this.
  6. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
  7. Trollbait
    12,417
    The tires are about a 1/2 inch larger in diameter. Suspension was probably lifted a little to give the larger wheels better fit.
  8. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    Would that mean you can't swap wheels from the higher trims?
  9. Trollbait
    12,417
    No. By fit, I'm thinking more along the lines of appearance. The LE could have been lowered a little to narrow the visible gap between tire and body panel to make it look better.
    Another possibility is the LE was lowered for better aerodynamics.
    MalachyNG likes this.
  10. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Which might explain it's better mpg rating.
  11. christiandflores
    christiandflores Junior Member
    26
    San Diego
    So no HUD anymore? Haven’t seen it mentioned anywhere. That would be very lame. It was the perfect complement to the offset speedometer and greatly helped retain visibility . It would explain why the new speedometer is so bulky.
  12. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    The instrument cluster is placed right below where the HUD would be. It's not needed in this setup.
  13. Prashanta
    292
    242
    Technology
    @Danny It'd be great if you could do something similar for the Canadian trims.
    moonmist and Mendel Leisk like this.
  14. christiandflores
    26
    San Diego
    Cost cutting.
  15. Prashanta
    292
    242
    Technology
    In this particular case, I'm not bothered by the cost cutting.
    moonmist likes this.
  16. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I'd like to know whether the steering wheel is partly in the way of seeing the new instrument cluster.
  17. Trollbait
    12,417
    That would mostly be from the difference in the wheel sizes.
    Weight difference between the trims can also be a factor in the ground clearance difference.
  18. dctalk523
    dctalk523 Member
    The OC
    Current prime is 3k more than regular Prius safe to say that the new Prime starts at 31-32k for base
  19. Prashanta
    292
    242
    Technology
    Looks like the larger wheels result in 5 mpg penalty. I think I'd be willing to give up a little handling prowess for that kind of efficiency gain. Low profile tires are also louder from what I gather. Toyota should offer the 17" wheel option on any trim.
  20. Mendel Leisk
    40,918
    You can switch ‘em, but yeah the cost and hassle is frustrating. In Canada Toyota’s only offering a couple of options, both 19” wheels. A serious shift of the goalposts.
