mpg numbers are shown on website for 2016 Prius
Discussion in 'Gen 4 Prius Main Forum' started by nategold, Dec 2, 2015.
  1. nategold
    nategold Member
    117
    38
    Arlington, MA
    I can't post the link since I'm new, but it was on hybridcars. Here is the gist:
    Due to go on sale this January, all numbers previously reported as provisional are now official, said Toyota media rep Sam Butto.
    Specifically, five of the six total trim levels will be rated 54 mpg city, 50 highway, 52 combined, and the lighter Prius Two Eco promises 58 city, 53 highway, 56 combined.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I just checked, and they are not currently live on fueleconomy.gov at the time of this posting.
    As for the hybridcars article, here is the article: Official EPA MPG Numbers Are In For 2016 Toyota Prius
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    So we still don't know if the measurements were done with the 2015 regs or the 2016 regs?
    I note that the article mentions winter mileage will suffer a lot, but we all know from Toyota's info. that the fourth gen. will suffer less, as it has better exhaust heat recovery and other enhancements that should improve mileage in winter. If I say it maybe it will come true? ;)
    Sounds like the previously released mileage figures were what they submitted, but couldn't call official until the EPA put their stamp on it.
    Also sounds like Toyota are slightly disappointed the mileage wasn't better, but don't want to talk about that. ;)
    I suspect it's just a reflection of all the work that went into the GIII. Very hard to beat good work! They did, just not by as much as they'd hoped!
  4. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    So, Gen III - 50mpg combined; Gen IV - 52mpg combined = 4%!
    austingreen likes this.
  5. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    If it's better in the cold weather (per your hopes) it should also be quicker to heat up, so the observed MPG over Gen3 might be good (on Fuelly for example). It's almost like the eco model is showing us the MPG potential.
  6. Sergiospl
    3,938
    1,351
    28
    Plus 28% more regen and engine off at higher mph
  7. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    Hybrid Cars article states winter MPG is low due to cold HV battery!?
    I do not think we have ever included "cold battery" on our list of reasons for lower winter MPG in a Prius. Interesting comment, but I feel they have probably read-across from Plug_ins (with larger batts) to Prius.
    #7 wjtracy, Dec 2, 2015
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Yes Prius is not up on fueleconomy.gov yet.
    MERGED:
    where is this from, do you have a link?
  9. Sergiospl
    3,938
    1,351
    28
    #9 Sergiospl, Dec 2, 2015
  10. bwilson4web
    15,519
  11. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    The fuel economy of the gen. 3 Prius was 3,9 Liters in Europe and 50 mpg in the US,so there was a difference of about 0,7 liters .
    The new gen. 4 Prius is rated at 3.0 liters in Europe,so considering it will have the same difference that would mean about 3.7 liters or 63.5 mpg for US rating !
    The gen. 4 Prius should be ratet well over 60 mpg I the US !
    BTW we don't even get the Eco-Version !
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    European and US tests do not test the same speeds, accelerations, or warm up parameters, so they do not compare well. (Nor do the Japanese tests) Toyota has been careful NOT to use one test to guess the results of another.
    bwilson4web likes this.
  13. civicdriver06
    797
    324
    Germany
    I am aware of this,and did say there is a difference of 0.7 liters between the cycle in Europe and the US ,so if we are ratet at 3.0 for gen. 4 using the European test cycle,that means you would be rated at 3,7 liters or 63.5 mpg if we would use the current US cycle in Europe !
  14. OldnCrusty
    OldnCrusty Junior Member
    Gen III mpg on this new test? It's not like there's no 2015 available to test.
  15. bisco
    49,429
    that would be nice to know, and give us the true mpg increase percentage.
    Tideland Prius likes this.
  16. Tideland Prius
    16,142
    ^ This.
  17. Sergiospl
    3,938
    1,351
    28
    So, only an increase of 2mpg combined after all the work that went into Gen IV?
  18. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It seems to be hard to improve on perfection.
    telmo744 and Sergiospl like this.
  19. Trollbait
    11,535
    A cold battery is lower to charge and discharge, and will be less efficient during startup in the winter.
    I once looked into 12 volt electric blankets for preheating my gen2's pack.
    The Prius is still a gasoline only car. Toyota has done when with the thermal efficiency of the ICE, but we are likely hitting the limits of spark ignition engines without paying high costs.
    I expect the gen4 to return better user fuel efficiency overall with the other improvements they added, but more big jumps as we saw in the past will likely require a plug.
    fotomoto and wjtracy like this.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    Issue is that EU and JC08 are mostly equivalent of EPA city rating, so 20% improvement on EU not equal 20% on EPA.
    Similarly JC08 gives much better improvement than 4% increase we see on EPA.
    I am regularly 8-9MPG above EPA, but I could see the merits of them rating it as low. My better half manages to get 5-7MPG worse and she is a slower and less aggressive driver. It is a puzzle for me how that happens.
    At least until Mazda releases SkyActiv2 with HCCI and 50% thermal efficiency.
