Official Prius Gen3 Brake Torque Specs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Nov 9, 2019.
  1. andreimontreal
    andreimontreal Active Member
    326
    107
    28
    Montreal
    Going crazy with finding all sorts of specs. I need those for the bracket, caliper, and banjo bolts.
    So far I gather 26 lbs for the sliding, 42 back and 101 front for bracket and 25 lbs for the banjo.
    EDIT from manual:
    rear 42 lbs bracket, 25 sliding pins, 25 banjo,
    front 101 brackets, 25 sliding and 25 banjo .... see bellow link to the entire repair manual
    Andrei
    #1 andreimontreal, Nov 9, 2019
    49,397
    they're not in the service manual?
    andreimontreal likes this.
  3. andreimontreal
    326
    107
    28
    Montreal
    You mean the car's manual? Let me check.
    EDIT: silly me, I had the repair manual from the forum. I found it. Thanks Bisco - to my rescue as usual. Brakes start around page 878, look in the index.
    #3 andreimontreal, Nov 9, 2019
    49,397
    no, the service manual. try the wiki page here for sources, or techinfo.toyota.com
  5. andreimontreal
    326
    107
    28
    Montreal
    Found it! Thanks Bisco. Was editing when you wrote.
  6. Mendel Leisk
    38,653
    I can post an excerpt tomorrow, just the brake section.
  7. andreimontreal
    326
    107
    28
    Montreal
    If it's for me no need - check the edit. Thanks.
  8. Mendel Leisk
    38,653
    Anyhoo:
  9. Bob Mintus
    Bob Mintus New Member
    Warren, OH
    Thanks, all for the post Just decided to check my brakes before a vacation and found that my front inner pads were worn down to the metal and just lightly polishing the rotors. I can say that this is my first set of brakes (I bought it with 118K mi so I don't know for sure if this is the first or second set at 231K mi).
    I can tell a difference in the pedal travel. It's higher now. Going to go easy on these as they break in.
