OGS Intelligence Position Switch
Discussion in 'PriusChat Website Questions' started by BadAssPrius, Sep 16, 2011.
  1. BadAssPrius
    BadAssPrius I got to make my Prius stand out all on its own!
    CHICAGO, IL
    I Just got my new OGS Switch Installed and i love it. You can change the LED color on this switch. SUPER EASY to install, because its plug and play. 1. You Remove the plastic center panel 2. Remove 3 nuts that keep the Blue shifter in place. 3. Remove the shift assembly and unplug it. 4. Place new OGS Switch and plug in. Like i said super easy and i looks GREAT!
    But make sure you have the vehicle OFF. I had my ACC ON when I unplugged the OEM shifter, then plugged the new OGS switch. It then showed "Check Hybrid System" on my dash. The way I made that go away WAS: With the car ON ACC Still, I Unplugged the OGS switch, connected the old OEM Shifter. Turned the car OFF, then ON. It then made the Check Hybrid System Go away! I then Installed the OGS switch back with the car OFF, Started the car and walla. No More Message.
      File size:
      28.6 KB
      1,057
      File size:
      30.9 KB
      968
      File size:
      31.3 KB
      959
      File size:
      67.6 KB
      1,028
  2. alfa737
    alfa737 Member
    126
    27
    How did you program the led lights, are there instructions in english some where on the web?
    any help in this would be gr8,
  3. JAYSONE
    JAYSONE Junior Member
    83
    Los Angeles
    How does the green color match up with the other oem buttons? How much did you pay?
