OGS Shifter - how to change colors?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tom Ham, Oct 10, 2012.
  1. Tom Ham
    Tom Ham Junior Member
    51
    Beverly Hills, California
    I just got the OGS Shifter from the folks at More Japan. The instructions are all in Japanese. Can anyone tell me how to change the button colors?
    Thanks!
    Tom
  2. ockevin
    ockevin Active Member
    493
    148
    Orange County
    I want to know as well....
  3. GloryThief
    GloryThief Junior Member
    59
    The Westside
    2013 Prius v wagon
    They have a video on their main page and it shows how you can actually change the color but it doesn't show how to get into that mode in the first place.
    More Japan :: Since 2003
    EDIT: I searched around on youtube and found this vid.
    Looks like you hold the reverse button down. I'm guessing it's while you turn the car on.
  4. El Nino
    El Nino Member
    210
    Michigan
    HOLD BRN while staring car for 5 seconds
    R switches colors
    N - Increases Brightness
    D - Decreases Brightness
    B Cycles to next configuration
    1st config - BND Color and Brightness
    2nd config - R Color and Brightness
    3rd config - OGS - Color and Brightness
    4th config - Sets your selections-
    Little trick I learned to get the letters to match the green of the dash. Unscrew the 3 screws in the back and you will have access to the white letters that pop in and out. Go to Staples and buy the lightest green BIC Mark It (exact ones in picture attached) and color in the back of the white letters. Then change the shifter color to yellow on the dimmest setting and it is a dead match!
    sonnyd510 likes this.
  5. Tom Ham
    51
    PERFECT! Thanks guys!
