Oh boy... This is bad.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SCPriusOwner, May 29, 2014.
  1. SCPriusOwner
    SCPriusOwner Junior Member
    2007 Prius with ~133k miles:
    We bought it used a little over a year ago and haven't any problems with it at all until now. Last night from a cold start, the check engine light came on along with the red triangle of doom.
    Checked the oil, it's fine, just had it changed a few weeks ago.
    Did the battery test, it's fine, 12.2v during the test and 14v with a load.
    Popped the hood, and I can see little waves in the pink inverter fluid when the car is in Ready.
    A drive around the block revealed that it's not running well at all... It could barely make it up a small hill.
    Before I get it towed to the dealer, what's next in line for troubleshooting? I'm guessing it's probably not the spark plugs since it doesn't buck or jolt??
  2. SCPriusOwner
    Oh I should've mentioned, the vent in the backseat was pulling air through it? Is that normal?
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    It's very hard to advise without the DTC codes for the warning lights. Once you bring it to the dealer, report the codes here along with any subcodes.
  4. JC91006
    16,672
    8,518
    A guess would be the HV battery might be going bad. If you are in a CARB state, you are still in warranty for a new one.....FREE. What state are you in?
  5. sockmonkey
    sockmonkey Junior Member
    84
    texas
    what is a CARB state? Is Texas one by chance? Just to be in the know...
  6. JC91006
    16,672
    8,518
    I believe this to be the current list. A CARB state warranty for the battery is extended from 8yr/100k miles to 10 year/150k miles warranty.
    With the exception of AZ, any year after the Model Year listed is also covered.
    MY 2004 California, Maine, Massachusetts, New York, Oregon, Vermont
    MY 2005 Connecticut, New Hampshire, New Jersey, Rhode Island
    MY 2007 Maryland
    MY 2008 Oregon, Pennsylvania*
    MY 2009 Washington*
    MY 2011 New Mexico
    MY 2011, 2012 only Arizona
    MY 2014 Delaware*
  7. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    That will be the day!
    To the OP, Yes, if you can hear the battery fan running on high, then you have battery overheating issues, which is usual when there is a module failure. It can also be due to a dirty cooling fan back there, but more likely this is another case of battery failure in a hot climate coming a bit earlier than elsewhere.
    When parking the car, use window shades. Don't let it bake in hot afternoon sun, as it makes life short for the HV battery. Use A/C when driving to keep the battery air intake cooler too.
  8. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Maybe normal, maybe not. Need more info.
    1. Was it loud enough to hear easily from the drivers seat of was it just whispering so that you had to place your ear up to the duct to hear it? Many people don't realize that this fan runs very often at low speed, too quiet to hear unless you place your ear up to the vent.
    2. How hot was the weather and had you been driving a lot of hilly or mountainous routes?
  9. SCPriusOwner
    ugh... so I picked up a code reader and this is what I have:
    P0A80 x2
    P3018 x2
    Looks like we're dead in the water.
    The fan is definitely noticeable from the driver's seat. Hasn't really been driven in the heat much since last Summer, South Carolina is rather flat and NOT a CARB state.
  10. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah that's definitely a sign of a bad battery. And of course P0A80 pretty much confirms it. :(
  11. bisco
    51,140
    don't bite on the dealers replacement price until you've done your homework.
  12. Rich12
    Rich12 Member
    176
    29
    But...but...the Prius is the most reliable car in the world. The web forums told me so!
  13. theshark
    theshark Member
    164
    Martinsburg, WV
  14. JC91006
    16,672
    8,518
    It's best to ignore the comments of Rich12, he's a very mature senior citizen that acts like he's 3. He seems to have been through a lot, you'll have to excuse his behavior.
  15. theshark
    theshark Member
    164
    Martinsburg, WV
    LOL Amazing..
  16. kwtchup
    kwtchup Junior Member
    Montreal, Quebec
    Sorry to hear about the issues with your battery...
    Keep us updated on your resolution, I'm hoping you don't have to shell out too much cash to replace it!
    It might be worthwhile to search the forums for those who've had similar issues, maybe you'll be able to find a good deal on a repair. At the very least, you'll be able to compare repair prices...
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Try and pick up a salvage pack if you can find one. They are fairly cheap and the install is easy. There are aftermarket rebuilt batteries that depending on your location might work out to be much cheaper to slightly cheaper. Then of course there is always the dealer.
  18. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    I'm so glad I live in the bay area. Prius servicers galore! Sorry about your battery, hope you find a speedy and great resolution soon!
  19. bisco
    51,140
    reinvolt use to be in nc.
  20. wjtracy
    wjtracy Senior Member
    11,360
    3,606
    Northern VA (NoVA)
    I think they still are as Taylor Automotive in Sanford NC ...now Dorman but you can see contact info at Re-Involt.com
