Oh you silly air box
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Acadianer, Jun 21, 2017.
  1. Acadianer
    Acadianer Member
    119
    82
    Technology
    Last Friday, I was checking my normal stuff on my vehicles, such as engine oil, washer fluid, tire pressures......and well, engine air filter.
    Voila what I found lol
    19149460_10155241660236113_1577132209196719152_n.jpg 19366431_10155241660226113_1703663114824945743_n.jpg 19146154_10155241660216113_2397612766475191402_n.jpg
  2. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    It's no wonder you found what you did; the engine air filter belongs in the air box, not on top of the inverter... :rolleyes:
    Acadianer and DonDNH like this.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It doesn't look like "nesting material". Maybe just ingested. Lots of trees and debris from them on the road?
  4. RRxing
    2,520
    1,791
    NEPA
    I'm wondering how it got in there past the air filter...
  5. David Beale
    5,963
    1,981
    Edmonton Alberta
    Isn't that -before- the filter?
  6. jerrymildred
    jerrymildred Senior Member
    11,513
    14,118
    Tampa, FL
    Yes, it's before the filter. Looks like it went through a big cloud of maple tree seeds.
  7. Mendel Leisk
    38,735
    Air flow is from the underside up through the filter.
    @Acadianer I'm guessing you're parking outdoors, and get a lot of overnight dew. That said, what the hell is with Toyota's bolt specs:
  8. bisco
    49,507
    any turds?
    Mendel Leisk and Raytheeagle like this.
  9. David Beale
    5,963
    1,981
    Edmonton Alberta
    "Rust converter" to the rescue! ;)
    They used to use Cadmium plating and they lasted. It's carcinogenic and so now banned, and zinc doesn't last as long (if used at all).
    Mendel Leisk and jerrymildred like this.
  10. jerrymildred
    11,513
    14,118
    Tampa, FL
    My PiP came from up north and has lots of rusty bolts, too. Also the connectors on the inverter. I cleaned them as well as I could and used POR-15. That was about 5 months ago. So far, so good.
  11. Mendel Leisk
    38,735
    Same area on our 2010 "garage queen".
    But yeah: Toyota bolt rust resistance is garbage. :mad:
  12. jerrymildred
    11,513
    14,118
    Tampa, FL
    Looks good, @Mendel Leisk. Do they salt the roads in B.C.? Or are you able to not drive on them when they are salty? Then again, if you're near sea level, I don't remember Vancouver getting much snow. Mine isn't all that bad, but I also treaded several places under the plastic radiator cover.
    #12 jerrymildred, Jun 22, 2017
  13. Mendel Leisk
    38,735
    Frustrating: seems like the banning of certain bolt coatings is leading to use of more toxic aftermarket remedies? And retro fixing this is never ideal. Better to do coated fasteners in a factory under controlled conditions, when everything is readily accesible, vs daubing on chemical, just where you can reach, after the rust has started.
    They salt pretty liberally up here, by no means as bad as back east though. Where things are really sand-pounding bad rust is the rear suspension. The bolts, the suspension frames, especially the welds. The frames look like they have a token coat of black paint, definitely no hot-dip galvanize. And all the bolts happily blooming rust.
    I took off a few plastic panels in vicinity of rear suspension, and the small bolts were almost rust welded on. Reinstalled them after an oil soak. Seems to me this at least is something they could have done at factory. Over regulation is creating a mess.
    I brushed and applied a wax/oil solution to everything I could get at, it is what it is.
    #13 Mendel Leisk, Jun 22, 2017
    jerrymildred likes this.
  14. Acadianer
    Acadianer Member
    119
    82
    Technology
    We've only owned the car since last September. Previous owner was in a wooded area.
    Rust? That ain't rusted yet LOL
  15. ChapmanF
    15,664
    With one older rust-prone vehicle I had once, it wasn't unheard of for me to take something apart, then stop at the hardware store for some stainless bolts and nuts to put it back together. They're cheap. Seems quicker than trying to clean up/coat some original bolt.
    Not something I would do to replace some class-10.9 load-carrying bolt somewhere, but small bolts holding covers on stuff, sure.
    -Chap
  16. Mendel Leisk
    38,735
    Hang around on street corners looking to score some of dos cadmium coat bolts. :whistle:
