Oil Analysis, Mobil 1 0W-16
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ken2116, Jun 6, 2022.
  1. ken2116
    ken2116 Junior Member
    37
    16
    Northern CA
    2019 Prius
    Just completed a coast-to-coast trip with 2019 standard Prius, close to fully loaded, w/ a fair amount of Interstate 'speed limit + 5mph ', with whole days into strong head winds where engine ran 100% duty cycle all day (normal driving ~ 65%) and was curious about whether 10kmi intervals are realistic. Mobil 1 0W-16, Toyota filter, 9.3kmi on oil, ~ 53kmi total. NAPA analysis results seem normal, Iron 7ppm, Al 4ppm, Si 22ppm, viscosity within range (6.9 @ 100 degrees) and TBN getting low (1.9) - the oil seems likely okay to 10,000mi. though am wondering if more cold starts would have consumed more of it. The first 2kmi on oil was a mix of around town and freeways. Curious about the Si level because many report lower - the air filter (Toyota) had 20kmi. with just light dust at the tops of the folds, clean below 1/8in. into folds and clean on back side. Will check again for air leaks. but things seem tight.
    Doug McC, CR94 and bisco like this.
  2. Doug McC
    Doug McC Senior Member
    1,009
    378
    Midwest
    2022 Prius
    Did you have any previous analyses done? Saw a YouTube video yesterday where poster claimed to have had samples of Toyota oil and Mobile 1 compared (both fresh, new oil) and Toyota’s oil showed more additives. I found that interesting.
