Oil and cabin filter avalibuilty
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gen 2 Tom, Jun 4, 2016.
  1. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I stop in Advanced auto, looking for an oil filter. They said there is a Fram, but nothing else. I use Mobil One or Pure One. Has anyone found filters yet?
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I normally do the cabin-filter, and the air-filter (ICE) myself, and get both from the local Autoparts store (~$15 each) and leave the dealer to change the oil and oil-filter as part of the 5k mile service.
  3. Mendel Leisk
    38,874
    I understand the oil filter is per gen 3; dealerships are sure to have them.
    49,691
    anything on line?
  5. Mendel Leisk
    38,874
    You could just order 3rd gen filter. I do order a lot of stuff online, but can't see the point for items like this, readily available locally.
  6. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Oh, is a Gen3 Prius the same cartridge type as the Gen 4? I'll stop in Toyota and compare the two part numbers, and report back. I had a Gen 2 which was a screw on filter.
    I do my own oil changes and filters. My Gen 2 that's all I did for 200K. Many times the dealers and other car repair try to make a oil change into a $500 visit.
  7. ChapmanF
    15,858
    If you're used to changing oil on a Gen 1 or Gen 2, Gen 3 is going to make you cuss.
    First vehicle I've owned that needs to be raised to change the wretched oil. Having a garage floor with a pit would be ideal.
    -Chap
  8. Mendel Leisk
    38,874
    My 81 civic, you just popped the hood and reached in from above to unscrew it. No fun.
  9. ChapmanF
    15,858
    My '88 Mazda you could change the filter from above, as long as the last person who put it on was you, observing proper torque. It was on the side of the engine right against the firewall, in a place where you could look at it or touch it, but not at the same time. Get a tool on it? Sure....
    For the first oil change I did myself, since the last person to tighten it wasn't me, I found there was just enough room there to drive a screwdriver through it to use as a handle. Definite feeling of relief when that worked.
    -Chap
  10. Mendel Leisk
    38,874
    The first time I loosened the oil filter, it'd been torqued at factory, likely to spec (18 ft/lb). It took moderate effort to break it loose. I continue to use that value, never any drama.
    One thing that's funny: there's a lot of mention of the little retaining clip on the side of the filter housing, that it's a big issue, you need 3 hands to get the housing off. I haven't found it does a thing, forget it's even there. It certainly does nothing when you're unscrewing the housing.
    I'd suspect it was concession to lawyers, due to the bare filter in the plastic housing, the O-ring on the housing, or whatever.
  11. CR94
    CR94 Senior Member
    2,642
    1,139
    Northwestern S.C.
    Same on my '81 Mazda, plus you also could easily remove the drain plug by reaching down from above. No crawling underneath required, and no chance of hot oil running down your arm.
  12. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Update, I stopped at the dealer today. They confirmed the 2016 Prius oil cartage filter is the same as the filter used in the Gen 3 the last few years. Toyota 04152-YZZA6. it was $5.75. The filter books at auto stores didn't have 2016 yet.
    I use small ramps to get my gen 2 off the ground enough to slide under it.
