Oil Capacity
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Darkamek, Oct 27, 2008.
  1. Darkamek
    Darkamek New Member
    Greenfield,WI
    I'm changing my oil today on my 08 prius and I can't remember how much oil I need to add after draining and changing the filter I want to say 3.9qt's. Can someone please confirm this for me thanks.
  2. Bob64
    1,540
    93
    Virginia
    3quarts puts you right between the low and full. No fuss, no messy measuring over and over.
    Do not use 4quarts, it'll put you a bit over the top. If you want to hit the top, then use 3.5 quarts (+-.2 quarts, depending on how much oil is remaining inside the engine/oil pan)
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    3.5 quarts will put you right where you want to be...
    Sam Brinson likes this.
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Toyota stated oil & filter capacity = 3.9 quarts (will put you 1/4" overfull)
    Actual/empirical oil and filter capacity ~ 3.7 quarts (will put you on the full mark)
    As mentioned by another above, 3 quarts will put you at the midpoint on the dipstick. I'm running 3.5 quarts at present, about 1/4" below the full mark. Anything between 3 and 3.5 quarts should put you in a safe zone that is in full compliance with the warranty/manual concerning dipstick oil level.
    The hard part after filling with synthetic is seeing the level at all.
  5. Patrick Wong
    18,210
    6,517
    Hold the dipstick so that it reflects the available light. Then you can see which part of the dipstick is coated with oil.
    I also use 3.5 US qt to refill.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Using a Mobil 1 "double" capacity oil filter adds a bit more oil. I use 3.5 quarts after filling and installing the Mobil 1 oil filter.
  7. richard schumacher
    7,682
    1,064
    United States
    Three is fine. There's no need to have a half-quart sitting around and getting old.
  8. Fred14
    Fred14 Junior Member
    40
    Southwest
    on a 2005 Prius how much oil is between the low mark on the dipstick and the full mark. Sister-in law is at low and is taking it to a shop for oil change. She wants to know how much it used.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    1.6 quarts;).
    If it’s low now, that’s a bad sign :cool:.
    Good luck and keep us posted (y).
    edthefox5, SFO and m.wynn like this.
  10. Mendel Leisk
    42,177
    (2nd gen) Repair Manual info:
    SFO likes this.
  11. Natalie Opsahl
    Natalie Opsahl Junior Member
    39
    Cortez Co
    wierd
    #11 Natalie Opsahl, Oct 25, 2020
  12. Sam Brinson
    Sam Brinson Junior Member
    Fort Wayne, Indiana
    Thank you for this. Was exactly the right spot on the dipstick on my 07 today.
