Oil Catch Can Bracket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EchoToPrius, Jun 6, 2020.
  1. EchoToPrius
    EchoToPrius Junior Member
    The bracket for the Ruien 0046 that NutzAboutBolts lists in their video is no longer being made.
    Does anyone have an alternative?
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Plastic zip ties, speaking from experience.
    saltdiscus and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    #3 Raytheeagle, Jun 6, 2020
  4. Mendel Leisk
    41,901
    Really depends on the can, where you're mounting, what you have, imagination.
    Raytheeagle likes this.
  5. tallprius
    tallprius Member
    62
    29
    texas
    Premium w/ Solar Cells
    i just made my own from about 3/16 thick old nylon kitchen cutting board (strong but flexible and easy to cut or drill or sand) 1.. but flexible cutting board at walmart or goodwill 2.. make cardboard template 3.. make big hole with hole saw
    and make can catch can fit tight so you can just pull it up to check it 4.. screw it into same spot using open hole on fender & u.r. done
  6. EchoToPrius
    The Ruien 0046 mounting it right behind the drivers side headlight just like in the video.
    Anything I can buy at Home Depot and modify?
  7. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Fits right behind the driver-side headlight.
    Ed Beaty likes this.
  8. EchoToPrius
    Mendel Leisk
    LDR Industries 516F385 5' Bag Fuel Line, 3/8"
    5 feet of 3/8 fueld line does not seem like it will be enough.
    If I am mounting behind the driver's side front headlight how many feet of 3/8 fuel line do I need?
  9. Mendel Leisk
    41,901
    5' MIGHT be enough. Run something you've already got on hand through the same route. Fuel line can usually be purchased by the foot through automotive retailer. Get 6'?
    Jim Swart and Raytheeagle like this.
  10. Simonak
    Simonak Member
    You can use any of the online 3d printing service upload the files and get quotes. Just make sure you use heat resistant filament and they are usually more expensive. Last print cost me I think around 20$. Also make use you increase infill to make it more sturdy.
    And if you can edit the file make it little bit bigger or just sand the opening after.
  11. EchoToPrius
    I got a quote online, way too expensive.
    Attached photos that I got on here look like the easiest and best cost solution. 141978_IMG_20180314_190605910.jpg 141977_IMG_20180314_190446745.jpg
    saltdiscus and Jim Swart like this.
  12. Simonak
    Simonak Member
    Prices went up but last order I used https://www.makexyz.com/ PETG its 18.90$
    but you should increase infill 50% or more and mayby lower height then its gonna be like 21-22$
  13. EchoToPrius
    Decided to switch up the mount location to the photo attached so I am below the PCV
  14. Mendel Leisk
    41,901
    You're planning to access mostly from below? That's my scenario, have mine mounted to a bracket that's atop the front/lower cross beam. I drain them when doing oil change, with engine under panel removed.
  15. Simonak
    Simonak Member
    If you are located in colder climate you need to empty the catch can quite often during winter times.
    tvpierce and Lightning Racer like this.
