Oil catch can moditication
Discussion in 'Gen 2 Prius Accessories & Modifications' started by NortTexSalv04Prius, Jul 10, 2018.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Okay
    I have reviewed a couple of others use of using oil catch can that is used with positive crank check valve //
    I have the following concerns
    Size of catch can small/big
    Material type all metal/clear abs
    inline or other
    Currently consider small inline clear plastic style aka same as air compressor air /oil separator style so quick visual inspection and drain can be relative straight forward
    maybe this
    1/4" Air Line Oil Water Trap Separator Filter For Compressor Spray Paint Tools | eBay
    SFO likes this.
