Oil change (0w20 or 5w20) in tropical regions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fopoku2k2, Oct 18, 2015.
  1. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I live in Ghana, West Africa which gets around 88F during the day most part of the year.
    My 2010 Toyota Prius is up for oil change soon. Unfortunately the type of oil required by the manual i.e 0w20 is not available here in Ghana. The only ones available are the 5w20 and 5w30.
    I've was told by the service shops here that 0w20 is only used in the cold regions. I've read on priuschat that it's good for hybrid engines due to their multiple on and shut downs.
    My question is. Due to cost and availability, can I stick to 5w20 oil?
    Thank you
  2. Mendel Leisk
    38,719
    You'll be ok. In North America Toyota says to use 0W20 at all temperatures, but around the world it varies. Australian Owners Manual for example, shows a traditional, wide range of oil weights.
    Page 480 of the 2010 Australian Owner's Manual:
    fopoku2k2 likes this.
  3. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    If it's available in Ghana, synthetic 5W-20 might be better than regular mineral 5W-20. One reason they insisted on 0W-20 in even warm parts of North America may be to ensure it's synthetic.
  4. zebekias
    zebekias Member
    101
    35
    Greece
    I bought Mobil 1 0w20 and had the dealer use that during my 35k km service. They advised against it saying 0w30 is what Toyota Greece recommends. I told them to use what I gave them :) Granted this was done in early September when the high temps have subsided. Ghana temps are definitely going to be sky high year round, if I were in your shoes I'd use Mobile 1 5w30.
  5. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    actually, checking around the gas stations that mostly sells these oils. I noticed that they mostly stock 5w40 . . . . . am I screwed???
  6. Mendel Leisk
    38,719
    Hopefully there are some specialty stores or automotive supply shops with better selection?
  7. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I doubt, but i am still looking
