Oil Change Access Door
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by regombos, Jan 31, 2011.
  1. regombos
    regombos New Member
    Michigan
    I have a 2010 IV Prius & I change my own oil every 5k miles. After my 4th oil change, the access door fell off due to bending it along the plastic crease intended to be a hinge. Toyota initially refused to replace it claiming I did not know what I was doing. But after constant yelling, they finally replaced it under the condition they would only do it once. Now after paying Toyota to change my oil (4 oil changes later) the access door fell off again for the same reason - full length crack along the creased hinge. If the change frequency moved from every 5k miles to every 10k, your car will be out of warranty and it is an $800 cost.
  2. regombos
    regombos New Member
    Michigan
    After 3 oil changes check the oil change access door to look for cracked hinge. Toyota claims this is an unknown problem and isolated to my situation... I don't think so. After this happened to me twice, I see it happening to everyone. You just need to be familiar with the underside of your Prius.
  3. regombos
    regombos New Member
    Michigan
    If this oil change access door is designed to be there, make them replace it if missing. Poor design, no question about it.
    52,577
    i took mine off completely and replaced it with an aluminum model made on a cnc machine at a local shop. door is hinged and has a locking cover to keep people from stealing my oil. all this for under a hundred bucks and well woth it!;)
    Silver Pine Mica and dbennett like this.
  5. Mendel Leisk
    42,077
    Haven't got to first oil change, but I raised it once for a dry run. I pulled out the 3 fasteners on that access flap, expecting it to flop down, but nothing happened. I finally pried it down enough to have a look, and was suprised at the effort needed. It seemed like the whole panel was flexing quite a bit before it started bending at the "hinge" point.
    If it's breaking off, I suppose you could sandwich the joint strip of some sort of tarp material on both sides, and pop-rivet it together, producing a flexible joint. Pretty funky to have to deal with this though.
  6. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Just did my fourth oil change, and I noticed that the "hinge" is tearing. I can foresee the need for some kind of legitimate hinge when the thin plastic seam gives out. I've seen some plastic hinges on the 'Net, I'll have to track them down again.
  7. markf57
    markf57 Junior Member
    78
    17
    Longmont, Colorado
    $800 bucks for a piece of plastic? That sounds steep!
  8. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    If this is truly the case, we need to push for a TSB of some sort. This is un acceptable.
  9. RufusNapkin
    RufusNapkin New Member
    36
    Can you give some detailed information about how it was done or by what kind of a shop (what to look for)?
    Thanks.
  10. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    my door is gone too....but it DOES make it much easier to change the oil :D
    Silver Pine Mica and prius808 like this.
  11. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    Do we need the door? What is the purpose of the door? fuel economy? Will our gas milage decrease that much? :confused:
  12. bisco
    52,577
    keeps the road junk out of there, specially in winter. perhaps a bit of aerodynamics. absolutely necessary? absolutely not.
  13. Mendel Leisk
    42,077
    Yes, $800 for that panel sounds insane...
    When I first looked at the underbody panels, just reaching under and giving them a tap, I was almost convinced they were metal: it is definitely thinner and harder plastic than Honda uses on their Civic Hybrid.
    I picked up a rubber utility mat and cut chunks of it for various app's, guess a replacement flap could be made out something like that: cut the same outline as the flap, put holes for the push-thru pins in the same places, and leave it an inch long at the hinge location. Assemble with the push-thru pins to orient it, then pop-rivet to the remainder of the underbody panel at the hinge point.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I plan to drill a couple of holes each side of the seam and run zip-ties through leaving enough slack so the door can still fold down.
  15. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    yup ! zip-ties as hinges ! even ferraris on track days survive on zip-ties !
  16. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Good idea spiderman! I'll be doing the same. Thanks!
  17. IMUSA76
    IMUSA76 IMUSA76
    Rhode Island
    I Just went to our dealer this morning, the door constanly was falling after the last oil change (4th one), thats what they did, added Zip ties to hold the door in place.
    the mechanic said "the plastic clips keep breaking off, the weight of the ice and snow build up on the door, pops the door open"
    This is a Poor design.:mad: this should be redesigned.
  18. Mendel Leisk
    42,077
    More likely each flex of the hinge point fatigues the plastic. The plastic used seems to be too brittle. Was this not a problem with earlier generations? Maybe they switched to harder plastic with third generation?
  19. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    This whole under engine cover is an idea new to the Gen3, the gen2 had no cover therefore no door to fall off.
    I had the four under body covers removed last year looking for rattles and I did some mileage tests with them on and off. http://priuschat.com/forums/gen-iii...5-mileage-test-under-body-covers-removed.html
    If removing those four large covers made no difference in mileage I can't imagine the oil change door would matter. But it does keep dirt out so when mine falls off I will probably rig up something like Spiderman mentioned.
    TsKarma and Mendel Leisk like this.
  20. Mendel Leisk
    42,077
    I've been thinking of something like this:
    A couple of strips cut out of rubber mat would substitute for the paper, pop-rivets for the staples, a nylon rod (or section of vacuum tube?) for the pin. A thin layer of silicone dielectric compound on the pin would likely help.
    I wouldn't do something like this until the door is actually breaking off, and try to flex it as little as possible in the interm.
    TsKarma likes this.
