Oil change adjustment for EV usage versus ICE usage
Discussion in 'Prime Main Forum (2017-2022)' started by dalcon95, Jan 24, 2017.
  1. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I guess there could be a two-fold answer to this question, which one is what Toyota recommends and what you can do after warranty period is up. The answer could be the same for both situations. The question is this. Can the oil change intervals change or adjust by the miles driven strictly on the ICE or does the oil changes have to strictly be based on the miles driven no matter which is being used to propel the vehicle for 5000 miles or 6 months? Ford supposedly has it calculated in the software for their plugin hybrids to notify the driver of when to change the oil based on the ICE mileage used. I didn't think Toyota did that though.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    From everything I can see of what exactly the one-way clutch added to the P.Prime does, the engine does still turn over, or at least can crank over, in EV mode. So, I think we're still stuck with oil changes...
    #2 mr88cet, Jan 24, 2017
    dalcon95 likes this.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    The engine doesn't turn in Ev mode.
    Toyota's recommendation is 10,000 miles or 12 months for oil changes.
    Tyfly, GA_Prime and dalcon95 like this.
  4. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Inspect every 5K miles and oil change every 10K miles. That's in the handbook.
  5. Trollbait
    12,351
    Out of warranty, going by HV miles only shouldn't be an issue. I wouldn't go over a year on a non-'synthetic' oil though.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I would not go over a year with synthetic oil and would not use non-synthetic at all. Would look for savings elsewhere.
    Samprocat and dalcon95 like this.
  7. Trollbait
    12,351
    Synthetic can go two years in a Volt. A blend should be good for that time.
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    This is a Prime thread and Toyota says one year.
    Prodigyplace and dalcon95 like this.
  9. Db17
    Db17 Member
    188
    92
    Visalia, CA
    You probably could go for a very long time. But it's pretty cheap insurance for what could otherwise be a very expensive repair.
  10. Trollbait
    12,351
    When's the last time you heard of oil issues in an engine?
    Modern oils are really good at their job. Their ability to lubricate doesn't grade with use. The oil needs changing because some additives get used up; mainly anti-seize ones that help prevent wear on startup, and acid neutralizers. The lower sulfur gasoline we are getting will mean the latter will last even longer in the crankcase.
  11. Mendel Leisk
    40,586
    The US yearly or 10K miles interval is pretty lax to begin with. Likely overkill with a PIP, but trivial expense anyway. Particularly if you DIY.
  12. bisco
    51,155
    there's no scientific answer, everyone has an opinion. here's mine:
    if you're keeping the car a long time, change it every year or 10k, whichever comes first. and use toyota recommended oil.
    if you want to pay for oil testing, you may be able to go longer. i don't know if that leaves any savings.
    if you only keep the car for 50 or 60,000 like me, don't bother changing it at all.
    then there's the people who say, change the filter every 10k and the oil at 20k.
  13. Mendel Leisk
    40,586
    Why I never buy used, lol.
    I know you wouldn't do that, but no doubt it's common.
    Prodigyplace and bisco like this.
  14. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I find it amusing that 'half' our posters do not trust Toyota and want to change their oil sooner than specified, while the other 'half' don't trust Toyota and want to leave it in longer.
    It must be tough being an engineer at Toyota.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Someone who sees the irony of life. LOL!! :D:ROFLMAO::LOL:
    I'm in the cheap peace of mind group. While modern engines are probably better than they were a couple decades ago, I have seen some NASTY sludge take out the poorly designed Mitubishi built V-6 in my son's old Intrepid. Putting in clean oil and a fresh filter gives me an excuse, too, to give the engine bay a close look. I changed both every 5K on my Gen 2. I'll probably go to 10K on the PiP since I'm getting twice the mpg and running almost 50% in EV. Even if the engine spins in EV, it's not contaminating the oil or putting much pressure on it.
  16. Mendel Leisk
    40,586
    Well, Toyota changes the interval too, 'round the world.
  17. bisco
    51,155
    yep, more marketing than science. also warranty.
    jerrymildred and dalcon95 like this.
  18. Trollbait
    12,351
    It is longer in Europe.
    The thing that ages oil the most is sulfur in the fuel. It reacts in the heat to form compounds that become acids when they mix with water(that's why moisture is bad in the oil). Europe has had lower sulfur limits in their petrol for years now, and thus why their cars can go longer between changes. Plus, their synthetic oils are truly group IV oils and not just high end group III ones.
    My understanding is that Toyota's 10k mile or one year interval is the same for all their cars. Regardless of it being a PHEV, hybrid, 4 cylinder car, or V8 truck. I don't think any Toyota engineer has worked on oil life in their cars in years.
    Other manufacturers have moved on from a set mile or time limit to oil monitor systems. These take into account the climate and the engine's operating parameters on when to call for an oil change.
    If warranty is a concern, stick to Toyota's schedule. The only harm it could do is waste some money and oil. Otherwise, it is your car, do what you want.
    Mendel Leisk and dalcon95 like this.
  19. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I'm kinda surprised that Toyota doesn't have an oil change monitor. It seems like it would be extremely useful in a hybrid, particularly plug-in ones.
    And for what it's worth, I just did a 5K oil change on my F-150, and the oil was looking much darker than the oil in the Prius at about 8.5K since the last change. It's the first car I've owned that uses synthetic oil, and I'm quite impressed so far.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    How do ya figger?
    The one-way clutch prevents it from turning backward, but doesn't prevent it from turning forward.
