oil change frequency dino vs. synthetic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wolfy90503, Feb 12, 2016.
  1. Wolfy90503
    Wolfy90503 Junior Member
    56
    Torrance, CA
    I change every 7.5k for synthetic and 5k for dino oil. Is that bad?? The MPG seemed to get a bit less toward the end but not too much.
    How often do you guys change oil?
    52,001
    i don't think the oil cleanliness affects the mpg, although, the syn might give a bit better than dino. those intervals look fine.
  3. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    That's approx. what I do too.
    Drain interval on Gen2 is 5000 miles irrespective of type.
    I use synthetic. Sometime I use Mobil-1 Extended Drain so then I feel 7500 is OK.
    Normally expecting better MPG as the oil is older due to thinning with gaso etc. but to be honest I have trouble seeing a change.
  4. Patrick Wong
    18,210
    6,510
    Not at all, that is exactly my practice. I'm using only full synthetic oils now.
    Prior to the Toyota V6 oil sludge issue coming up in the early 2000s, the Prius oil change interval with conventional oil was 7.5K miles. This changed with the 2004 model year when the MAINT REQD light was added.
    This sludge issue apparently was not an issue outside the US, so the other geo regions did not get the MAINT REQD light. Since the issue was region-specific, that might lead you to conclude that average owner maintenance practices and/or the average oil quality used were below par in the US.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    10,000 miles minimum for Mobil 1. Easily 15,000 for Redline and or Amsoil.
