Oil change interval...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by socal13, Mar 13, 2019.
  1. socal13
    socal13 livin in the foothills...
    262
    86
    Altadena CA
    I have 42000 mi on my 2013 Persona... I have gone 4000 mi in 7 months. Do you think I should change the oil (and get a tire rotation too)? Also, my 2015 Avalon has only 11000 miles and I have gone only 1500 miles in the past 7 months. Oil change due to over 6 months? Thanks for advise.
    49,371
    I do similar miles and change it every spring.
    Keep your eye on the 12v health with that kind of driving
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Once a year or 10k miles, whichever comes first.
    I try to rotate the tires every 5k miles.
  4. socal13
    262
    86
    Altadena CA
    I just got a new 12v battery after six years.
  5. bisco
    49,371
    Your probably fine on the Prius, but the Avalon must sit a lot. Much bigger battery though?
  6. FuelMiser
    FuelMiser Senior Member
    1,293
    883
    Monument, CO
    ...if you filled with 0W-20 last time.
    jzchen likes this.
  7. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    It still surprises me that any member here, knowing full well about the 3rd Gen Prius having known oil consumption issues and no tolerance to low oil events, would stand by and endorse Toyota's "minimum" OCI recommendations.
  8. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    My ‘14 iQ manual notes to use a higher weight in increased load/higher stress operating conditions. Since the first number is more for cold start I was thinking 0W-30. Thoughts?
  9. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    What is your evidence that the oil consumption issues are caused by not changing more frequently? That's a common assumption, but I have yet to see a good explanation.
  10. nicoj36
    nicoj36 Active Member
    495
    158
    That's true. The higher mileage ones do burn-up oil and needs to be refilled after a while. I agree the 10k / 1 year interval is a bit excessive and pushing it. The longest i'll push my prius is 6 months. But I spoil mine and change it every 4 months lol. I do live in Michigan where the weather and temps changes drastically.
  11. Mendel Leisk
    38,644
    Yeah but maybe you're conflating the frequency of oil change with oil check?
    I'm firmly in the change it early/often camp, no ambiguity there. But still, if you very regularly check your oil, oil consumption is not going to bite you. Still, it's that "if" that bites a lot of owners...
    CR94 likes this.
