Oil Change Los Angeles - West Side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stevarino, Jun 29, 2010.
  1. Stevarino
    Stevarino Junior Member
    Palo Alto, CA
    2020 Prius Prime
    Anyone have a good referral for a mechanic on the West Side of Los Angeles? 'Need the first oil change and am leery of the ineptness of dealer mechanics. Sub question: Why must the oil be changed every 5,000 miles? Dealer revenue stream or bone fide need? Many thanks.
  2. Patrick Wong
    18,198
    6,464
    If you wish to maintain the 5 year / 60K mile powertrain warranty coverage of the engine, then you'll need to prove that you've had engine oil and oil filter changes according to the maintenance schedule, in the event of an engine failure.
    If you don't care about maintaining the powertrain warranty coverage of the engine then you can replace the engine oil when you feel like it. Some owners have high confidence in the synthetic oil they are using and have adopted extended change intervals of 10K miles or more.
  3. fwbrc51
    fwbrc51 Junior Member
    61
    Fort Walton Beach / NW Florida
    if some owners are using synthetics for 10k, what filters are they using?
  4. almypal26
    almypal26 Member
    101
    So Cal
    Patrick,
    I have a 2010 Gen III. Attempted to change oil at 15k on my own. Used a 65mm oil wrench to change the cartridge filter, but was not able remove the cap housing the filter (engine was warm). Any help would be greatly appreciated.:confused:
  5. Patrick Wong
    18,198
    6,464
    I don't have a 2010 so I don't have personal experience with this. However, what is the problem:
    - the wrench fits, but you don't have sufficient leverage to turn the cap, or
    - the wrench is slipping, or
    If the first, then you'll need a wrench with a longer handle. I have a couple of pieces of metal pipe that I use for that purpose as well as a cheater bar.
    If the second, you'll need a better wrench.
    If the above doesn't help, please say more about what your problem is. Also, sometimes people try to do this job without first elevating the car and using jackstands to hold it up. If you can clearly see what you are doing and can get yourself under the filter, maybe that will improve your ability to exert force on the wrench. Good luck.
