Oil Change Question
Discussion in 'Gen 2 Prius Main Forum' started by jsnschmasn, Feb 3, 2008.
  1. jsnschmasn
    jsnschmasn New Member
    17
    St. Louis, MO USA
    Hello all,
    I had the oil changed at 1k. I asked for synthethic but didn't specify the weight so the Toyo dealer used 5w20. They also filled it perhaps an 1/8" to 1/4" over the full indicator on the dipstick, measured on a cold engine. I've reached 3300 miles now. I've read several posts which get quite technical regarding oil weights and viscosities and I really can't pinpoint my answer. Without getting overly technical, does anyone think I need to worry about this?
    Thanks in advance for your help.
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I'm not the expert but I don't think you need to worry about the viscosity. However you may want to siphon out enough oil to get it down to the full mark at least. Too much oil will foul a sensor, throw a code, and the computer will shut down the engine. This can be quite a thrill ride if it happens on an interstate.
  3. removeum
    removeum Member
    407
    El Paso, TX
    There is a TSB regarding the overfill issue you should talk with the Prius Tech. Your manual also states to use 5w/30 oil.
  4. Ellie
    Ellie New Member
    The manual specifies that the oil be changed every 5K miles. How much benefit is there to doing it more often? Sorry if this isn't the place for that question...I'm just curious as to why one would do it at 1K?
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    sure about that?
    one ran with 8 qts in it... (double fill by express lube genius) no codes, no shutoff, no lights. just smoke. lots and lots of smoke.
    eventually spit out a code for out of range o2 sensor reading... cleared itself after a few starts.
    drained the oil, filled it right, ran in forced idle for about 45 min, smoke cleared out, all was ok.
    you may be thinking of the classic prius issue where the engine won't start?
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I wouldn't worry about the 5w20 viscosity at all. As far as the slight overfill over a long period of time several overfills will probably prematurely shorten the life of the O2 sensor, but it sounds like they put a straight 4 quarts in, giving you an overfill of less than half a quart, not much to really worry about.
  7. richard schumacher
    7,663
    1,038
    United States
    But don't let them make a habit of it. Tell them to put in no more than 3.5 quarts, and that you will check the level on their drive before you leave. And then do it, every time (this is a good idea regardless; someone forgetting to tighten the drain plug or the filter or even merely leaving out the dipstick can ruin your whole day).
    For more confidence you can bring your own oil and have them use that. 3 quarts is both convenient and sufficient because some of the old oil remains in the sump and coating the internal surfaces. In my experience three quarts always leaves the level halfway between ADD and FULL, which is plenty.
  8. jsnschmasn
    17
    St. Louis, MO USA
    Ellie,
    That's a valid question. I actually do the 5k maintenance intervals. In this case, I just remember reading that some of the metal shavings might break loose in the first 1k or so(true or not true it stuck in my brain) and I really believe that synthetic is superior to dino. Perhaps it's more a mental thing than scientific. I'm just very particular when it comes to maintaining my autos. I wouldn't freak out if I went w/o a change for say 6k but I'd certainly feel better about it knowing I have synthetic running in it. I'm certainly not a mechanic or chemist and cannot validate my arguments without just saying it just makes me feel better. :D
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The oil "experts" who have had analysis done have concluded the specified change intervals are about right. So no real benefit to changing more often.
    As far as an "overfill", with a full 4 qts, my personal experience shows this is a non-issue. You can get silly if you like, but 1/2 qt isn't going to make any difference, at least that I can measure, see, or experience. You have to put in several qts extra before anything "bad" happens.
    I put in 4 litres with no ill effects, including on mileage. I even put in three litres of 5W30 and one of 10W30 (using up the oil I have). Oh My!! ;)
  10. thfrancis
    thfrancis New Member
    39
    SF Bay Area
    My car was slightly overfilled when I purchased it. Keep in mind that the original oil in our cars was put in by the factory, not the dealership. If the dealerships are slightly overfilling, then they are consistent with the amount of oil the factory is using. (At least that was my experience).
  11. JimN
    7,028
    1,116
    South Jersey
    Galaxee, it happened to the white 2007 Prius at the office. The car was towed to the Toyota dealer. The place that did the oil change paid for the tow, the part & the rental since it wasn't a warranty trip.
  12. galaxee
    9,810
    465
    MD
    what part? if a part had to be replaced, it almost certainly couldn't have been the oil. you never know with some places, you know?
    DH won't rule out an o2 sensor from the realm of possibilities but that's some pretty hardcore overfill to do THAT. not just 1/2 inch over the full mark.
