Oil Change Recommendations?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vysse, Aug 10, 2016.
  1. Vysse
    Vysse Junior Member
    52
    I just got a 2009 Prius and the Maintenance Required light popped on at 117k. I looked into it and it seems that the last maintenance was at 112k. From what I can tell it seems that the maintenance done is about 2k miles after it should be at this point. Anyways with this in mind I should be doing my Oil change. I was thinking about taking it to a Toyota Dealer but am unsure what I would be looking at overall in price. Should I just take it to Jiffy Lube? If so what oil should I be using as I have seen conflicting information. Also is there any thing else to look out for?
  2. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Based on other PriusChat forums, I see that 5W-30 is the oil to use for gen 2. I don't know what I use in my gen 2 and I know to use synthetic in my gen 4. I'd look on Yelp for an independent car shop, not mechanic. I stopped using my Toyota dealer years ago (scammers) and went to an independent shop that specializes in Japanese and American cars.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Anyone can change the oil in a Prius, it's the same as any other car. (It's also a fairly simple and safe DIY project.) Shop around for price, use coupons, etc. They'll try to sell you other services from wipers to transmissions.
    At this point you should be checking the oil level on the dipstick every other gas fill up. Aging Priuses have been know to start burning oil while otherwise running perfectly. In fact, look at it before you get it changed. If it's near the lower mark, it's consumed nearly 1.5 quarts, over a third of the capacity, and you'll need to keep it topped off in the future.
    51,141
    given the choice of toyota and jiffy lube, i would choose toyota. that being said, i use the local gas station mech. he's conscientious, although not cheap. i think my gen 2 oil changes were around $40. - $50.
    check your o/m, you got 2 ait filters, tyre rotation and also plugs and fluids coming soon. and serpentine belt/water pump?
  5. Vysse
    Vysse Junior Member
    52
    I think the water pump was changed already will have to look at service records again. According to the dealer I bought it from they just changed the brakes and did a tire rotation. I know I'm looking at a full tuneup that I will probably do at the recommended 120k. I found a guy nearby that'll do the oil change for about 50 and it comes with a free 30 point inspection. It also is a place that specializes in hybrids. Going to Toyota dealer today to see what price I'm looking at there.
  6. 'LectroFuel
    880
    673
    IMO, never use Jiffy Lube, Pep Boys, Valvoline, etc. The dealer at least won't trash your car.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Just beware of those free "30 point inspections." Many times, that's when they come up with all the phony crap, unnecessary services, rip-offs, etc.
    Do you have the original maint manual? (Or you can find it online.) If nothing is obviously broke, or leaking, and it drives ok, no strange sounds.... why not just do what it recommends in your manual?
  8. Vysse
    Vysse Junior Member
    52
    I am doing what it recommends in the manual.
  9. Coast Cruiser
    2,267
    2,571
    Then you are good to go. :) Find a mechanic or dealer that you like, and ask for the oil viscosity that the manual specifies.
    And what happen to the $29.95 "express" oil change?! I get things in the mail from the dealer, and it now costs 60 bucks!
  10. Vysse
    Vysse Junior Member
    52
    Synthetic oils weren't prominent back then and they are now.
  11. bisco
    51,141
    i pay $90. for an earl change.
  12. Mendel Leisk
    40,575
    What is that?
    It used to mean maintenance of the distributor and new spark plugs, but now there's electronic ignition and long life plugs, it doesn't really mean anything.
    #12 Mendel Leisk, Aug 11, 2016
  13. bisco
    51,141
    en tune up.;)
  14. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    Agree with above...avoid Fast Lubes/ Jiffy Lube etc.
    (Main issue seems to be a specific wrench for a Prius oil filter.)
    Check your owner manual in regards to "dino" or synthetic oil and what viscosity.
    My local dealer is always running oil change specials. I believe it is $39.95 or so...maybe less.
    DIY Costs
    5 quarts = 30
    Filter = 10
    Drain plug seal = 1
    Environmental waste fee = 5
    Plus you may need that special filter wrench.
    Have fun.
  15. Mendel Leisk
    40,575
    Sharpening my pencil, and in Canadian dollars:
    4.2 liters: $18.90 (Toyo 0W20 bulk @ $4.50 per liter)
    Filter: $8.53
    Drain bolt washer: $2.20 (a bit much :()
    No additional charges, environmental for example.
    I'm using an old Honda filter socket, same dimensions, works fine.
    #15 Mendel Leisk, Aug 12, 2016
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Go to the dealer and buy a couple of OEM oil filters. There like $4 a piece. I would buy a new pan bolt. There only $4 each too. You never know how beat up the existing bolt is. Its a sacrificial threaded bolt. I change mine about every 5 changes.
    Go to Walmart buy a jug of 5 quart Mobil 1 5-30 for $24.95.
    A G2 Prius takes 3.5 quarts so every other change will be free. Just don't give the whole jug to the dealer as he'll put the whole thing in. They don't speak Englash back in the oil change dept at the dealer.
    I would pour 1.5 quarts into a container at home no matter where I took it. Then in the morning after all the oil has drained back check it before you start the car.
    The last 3 changes I have used Redline Motor 5-30 oil which is very high performance oil and has a ZDDP package in it which our solid tappet car really likes. Really quiets this clakity motor down and runs very smoothly and has essentially stopped my minor oil loss issue at 96K miles. It touts a operating temp of 40 weight.
    Amazon.com: Customer Reviews: Red Line 5W30 Synthetic Oil - 1 Quart, Pack of 12
    Eastside and cyberpriusII like this.
  17. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have always done my own oil changes, but now with two new cars, I can't! My wife's Subaru has a lifetime power train warranty that they will void (after the manufacturer's warranty runs out) if I change that oil myself. My Prius Dealer does "free" oil changes for as long as I own my 2016 Prius (but only at 10k mile intervals so I can sneak in fresh syn oil at the 5k mile point).
    JeffD
  18. tvpierce
    tvpierce Senior Member
    951
    881
    Maine
    2013 Prius v wagon
    Somebody is giving you incorrect info. The 1975 Magnuson–Moss Warranty Act, as I understand it, states among other things that if a warrantee requires service be performed by the dealer, then that service must be provided free of charge.
    I presume the dealer is using synthetic oil. If so, there's no reason to change your oil at 5K miles -- 10K is more than adequate.
  19. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,700
    Mars Hotel
    As said, your warranty cannot be voided if you, or someone else competent, does the oil change. You had just better keep all receipts, tear a flap off the new filter box and write down the day and miles when it is changed.
    DIY oil change for me on my GENII:
    $5 for a Toyota Filter
    $10 (more or less) for Castrol Dino
    $1 for paper towels (HAHA)
    $15/$16 total USD.
    I have a Fumoto valve, so no need for washers, etc.
    Used oil can be left at the curb
    edthefox5 likes this.
  20. Mendel Leisk
    40,575
    Funny, I've never had a language barrier talking to the multi-ethnic folks at our dealership, and I don't know Punjabi, Farsi, Cantonese...
