Oil change when I can't get it hot enough
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ukiltmybrutha, Oct 18, 2020.
  1. ukiltmybrutha
    ukiltmybrutha Member
    139
    22
    VA
    I would like to change my oil while waiting for my vehicle registration and title from the State as to use time I might not have available later on.
    The thing is, I won't be able to drive it very far on my private road without tags.
    It wouldn't be my first time doing a cold oil change on a vehicle. It is FAR from the end of the world but I'd rather do an oil change when the car is hot.
    I don't see how I can get the vehicle too hot in the driveway.
    Should I just change oil with it cold or make an effort to get it hot?
    Any techniques you would suggest?
    Thanks for your time.
  2. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    1. You don't need to drive it. Just start it up and run the A/C (or heat) low (or high). The engine will run as necessary. Once the engine has warmed up, it will shut off automatically. Then you can change the oil.
    2. Even if the engine is cold (but not freezing cold), most of the oil will drain out.
  3. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    ^ that. It might take a little longer than a regular car but it will get hot enough.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    5W-30 is thin enough that it shouldn't make a huge difference unless it's winter coat weather.
  5. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I did the EPR treatment on our Prius one evening last week, then drained the oil the next morning (in the garage, so somewhat warmer than outside). Even draining through a Fumoto drain valve (considerably smaller passageway than the drain plug opening itself), it didn't take long for the drips to stop.
    #5 NewHybridOwner, Oct 18, 2020
    jerrymildred likes this.
  6. ukiltmybrutha
    139
    22
    VA
    I don't believe that the A/C works on this vehicle.
  7. Mendel Leisk
    41,889
    Run it for 15~20 min in Maintenance Mode? It will run continuously, heat up good.
    Not sure if 3rd gen chicken-dance is same, so fwiw:
    1. Two push start button without foot on brake.
    2. Depress gas pedal (completely) twice.
    3. Depress brake pedal and shift to Neutral.
    4. Depress gas pedal twice.
    5. Press Park button.
    6. Depress gas pedal twice.
    Confirm Maintenance Mode displayed on dash, then depress brake and start button. Engine starts and runs continuously, till shut down by push of start button.
  8. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,839
    Hyampom
    Some people would just be a scofflaw and drive it a mile or two on the public road. Not that I would ever recommend doing that and I would never do it myself.
  9. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    You can also force the engine to run at about 2900RPM in park just by flooring it for a couple minutes.
    dig4dirt likes this.
  10. ukiltmybrutha
    139
    22
    VA
    Are you saying that if I floor it it will stay pegged at around 2900 immediately or that flooring it will cause it to reach 2900 rpm at some point?
    Thanks.
  11. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    In my experience, if you floor it, it will ramp up to a consistent ~2900 RPM after about 5 seconds and stay at that speed continuously. A minute or two at 2900RPM should be enough to heat it up for an oil change.
  12. ukiltmybrutha
    139
    22
    VA
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Don’t bother getting the oil hot just open the dump bolt and let it sit on a cold car. Let it drip for a while It’s not high viscosity.
    You don’t do this much so learn how to dump the oil out and take the oil filter off without dumping the oil on your arm. It’s kinda messy.
    Don’t want to learn with hot oil.
    When I change the oil on my cars there always cold.
    jerrymildred and cyberpriusII like this.
  14. cyberpriusII
    1,157
    1,839
    Hyampom
    edthefox5 likes this.
  15. ukiltmybrutha
    139
    22
    VA
    Valid points. Finally got tags on it so now I have options.
  16. edthefox5
    10,096
    4,834
    Clearwater, Florida
    As a side note there’s a lot of oil trapped in the VVT section of the engine the VVT filter and it’s channel the solenoid tank and the cam vane so your not going to get 100% of the oil out no matter what you do.
    If you want to do it better just increase the next OCI.
    DIY it’s a very messy operation. Last thing you need is hot oil.
  17. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    Fire it up and let it run until the motor stops. It's warm enough to change the oil and filter.
